Black Hole Vu+ Solo 2.1.7
Hi, my Vu solo has 2.0.9 version and works real good except for downloading Vhannibal settings. My friend had just bought one and I told him that we will try 2.1.7 cause it has ipptv and see how it works but When we was trying it it was crushing ( green screen and restarts again ) a lot and even when on a channel it was like updating all the time. Still have to say thanks to the hard work I I really would like to know if there`s some thing wrong with it. Thx
We need the crashlog to try to determine the problem occourred
Black Hole 2.1.7 MultiBoot
Hi All Just downloaded the above but when I reboot I'm getting a blue screen with VU+ Black Hole but no version number - unlike your purple screen saying 2.1.7 so have I downloaded or have I just done a factory reset or something please? When I go into the "about" from menu it says I've got 2.1.7.(is it 01- sorry not at receiver right now) I used the USB method and at what point of the upgrade does one remove the USB stick please - mine did an automatic reboot after telling me upgrade completed? Many thanks for all help offered Decoder
The best image I found for my Vu+ solo and it works perfect without any crash logs is 2.1.4
I turn off dts down mix and now DTS (from video on hard disc) does not sound in my AV-Receiver YAMAHA for OPTICAL digital sound.
Earlier on older firmware it worked!
Check please anyone at the digital output without Downmix?
Sorry! Everything is working!
I mixed inputs / outputs on the av-receiver.
It does not work with optical out on my TV Samsung, again sorry for the unnecessary worry!
