Black Hole Vu+ Solo 2.1.7
Ciao, I have a old VU+Solo dated 2011 , can I use this version ?
Thanks
For my solo which is an old Vu too but I'm happy with, I tried Blackhole 2.1.4 and 2.1.7 and now I'm using Open BlackHole 0.1updated
The last one I found it better then all
What changes between Blackhole and Open BlackHole ?
OPEN BLACK HOLE 0.1
What is Open Black Hole ?
It is an exciting new project from the same team that produce the Black Hole images.
This new project is based on the PLi git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all PLi plugins, feeds and skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the standard Black Hole images, we have also added the Black Hole addons panel and included Full HD skin support, OpenGLes Animations and of course included Xbmc .
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any Open Black Hole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new Open Black Hole image ?
No you don't have to upgrade to the new Open Black Hole image, this image is completely separate from the original Black Hole image, this is simply a new image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new Open Black Hole image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new Open Black Hole image is an additional project and we are fully committed to all images.
Where can I find the Open Black Hole git ?
The Open Black Hole git is located here: http://git.vuplus-community.net
For all info:
http://www.vuplus-community.net/board/forums/open-black-hole-general-discussions.67/
Thanks works out of the box, even iptv channel works smooth in compare of my previous 2.0.9 BH image. RTLZ works now smooth.
Thanks, great image !!!
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
    • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
    • New skin MX i6p By Matrix10
    • Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
    • Xbmc Support 576/720/1080 resolution
    • Updated Vuplus-Blindscan
    • Updated HbbTv
    • Updated WebManual
    • Added Sat>Ip Client
    • Included UiPositionSetup
    • Removed MeoBoot
    • Added OpenMultiBoot
    • Updated Lcd4Linux
    • Updated MediaTree (usb tuners drivers)
    • Fixed random socket error
    • [ScanSetup] fixed error on complete scan with T2 tuners
    • [ScanSetup] fixed TT3L10 automatic scan problem
    • [unicable] support JESS(EN50607) and update unicable.xml
    • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Cioa, non riesco a trovare il link per scaricare l'immagine. Come si fa? Grazie
hello i am new in this forum i want to update my vu+ solo from 2.1.4 to 2.1.7
but i got a question do i lose my channels lists(data for the user)?
thanks
thanks
Make a backup with a settings editor to your PC.
You can use one of the follows: ( download it from the next links and install it ).
Dreamset -> http://www.vuplus-community.net/board/threads/dreamset-32-e-64-bit.3595/#post-198937
DreamboxEdit -> http://www.vuplus-community.net/board/threads/dreamboxedit.18975/#post-179072
After flashing the new image, you can roll back your channels list, by uploading it to your STB.
If your STB is a Vuplus Solo you can flash it with the last image, that you can download here --> http://www.vuplus-community.net/board/threads/black-hole-3-0-1-f-vu-solo-oe-3.27284/ Version 3.0.1.
After flashing it don´t forget to make an online update to handle the lastest version.
