Black Hole Vu+ Solo2 1.7.9-3
i have BH image 1.7.8 on my ultimo with 500 GB hdd, now i formatted the hdd, and it worked, after a few days, i need to formatt again, cuz it says NO hdd or you need to formatt it, never had that problem with open PLI, someone else that problem ??
PS maybe its already discussed somewere, but couldnt find it.
Joland
You posted into the wrong thread.
Hello. I'm new here. Not new with sattelite. A have a new solo2. I will install blackhole.. is there a c.c.c.cam insite in the firmware...? or must i download it and instal as ipk ?
EDIT BY ADMIN:
SORRY YOU NEED TO READ THE RULES,
You have been banned for 7 days, which will give you plenty of time to read the rules.
Merry Christmas, see you just before New Year :)
Hello everyone. I have just bought my first vu (solo2) and I have set up my box without any problem. Can anyone explain the benefit with loopthrough? I have just single LNB and using one tuner only.
i have a problem
my original vu wlan-stick 300mbit works only at front usb correct. I have ip automatic. On the backsite i have an old issue, can not generete passfrase:wallbash:
Sorry about my mistaks
Hello,first I want to thank the team for your effort to make this receiver the best on the market. I want to ask a newbie question. What is the procedure for the transcoding feature?Also which is the difference and the meaning of only 2 ports available(8001&8002) in this plugin? I managed to work inside my home but only in my iPad.If I am at a friend of mine house an I want to watch the channels in a windows PC which is the procedure?(if possible)A tutorial would be a great thing.Thanks again
i have a problem
Use an extension cable for USB wlan-stick
and put wlan-stick on place without interference.
How To Have HD PIP and record
from different transponders and a single LNB.
from different transponders but with the same polarization
with only one cable (one LNB)
(For those who do not know one standard single LNB can not work at the same time on the two polarizations V and H)
1.Connect the antenna to the tuner B
2.Config Tuner A loopthrue to TUNER B
3.Config Tuner B (for rotor Mode positioner ,simple Longitude/latitude or DiSEqC config if you have no rotor)
  • Like
Reactions: 2jj
got my Solo2, flashed the BH 1.7.9-3 , WLAN stick works in the back USB.
I have 3 sats on DiseqC in advance mode (tuner A) and sofar i have 2 peoblems :
- SNR is very low (45-55% max) compared to 85-90 % on my Dreambox !
- the really silly thing is that upon switching channels the system waits till it gets the signal ( the SNR says 0% and this satellite symbol " no signal" appears) then it is fine again.
it looks like as if the speed of zapping is faster than the speed of handling the signal !!! or maybe it is my DiseqC settings ?
hello everyone.
I just buy a solo2 and i use your image,
i want to ask ,this image is oe 1.6 or oe2.0?
thank you
Is it possible to have subtitles in Media Player? I cant get it working!
I'm talking about and .mkv file and .srt subtitle (in portuguese).
Nobody can help me with this??
During play, press AUDIO button then YELLOW button and select the subtitles you want.
Tested with DIVX files and all works properly with SRT subtitles.
Subtitles files MUST have the same name of your video file (except the extension of course)
Thanks a lot @angelofsky1980 for your attention! :)
I should have something wrong here then :)
Thanks once again ;)
