Black Hole Vu+ Solo2 1.7.9-3
Have you set it as 2nd cable to motorised lnb ?
If so, swap them over so tuner B is the motorised cable and set tuner A as 2nd cable of motorised lnb.
Let me see if I get it right.
Current config:
Cable 1 (motor) -> Tuner A
Cable 2 (straight to LNB) -> Tuner B
You are suggesting to swap them over:
Cable 1 (motor) -> Tuner B
Cable 2 (straight to LNB) -> Tuner A
Then change Tuner B to USALS and Tuner A to 2nd cable of motorised LNB.
I'll give it a try and I'll let you know.
Happy new year! :)
Yeh give that a try.
Happy New Year to you too
LOL! It was the most stupid of problems! EHEHEH
When I plugged on to the tuner B I unscrewed the cable from the plug. Alas it couldn't work! :) I reattached the cable to the plug and all works as expected!
I did try to watch BBC on 28.2, and now i can, while with the old DB800HD I could not. So now I am able (on sunny days) to watch BBC as well! I am very happy with the Solo2! :)
Happy New Year!
I have a strange problem ,when i install bh and scan hotbird i found at provider netmed the cinema1 and sport1 on 11823 ,this is right,
If i change satellites xml (reinhard) at etc/tuxbox and scan again then these channels are at 12207 and i have 0 snr.
Its very strange ,is this driver or tuner problem?
Any ideas?
Thank you
Can anyone chek his solo if have the same problem when change satellites.xml?
do you have satellites.xml in etc/enigma2 as well? If you do delete it as it has priority over satellites.xml in etc/tuxbox
I've put attached file to etc/tuxbox and cinema1 and sport1 are on 11822H but I've got my own channel list...
do you make scan the hotbird after changing the satellites.xml at etc/tuxbox?
with the first scan of BH all is ok,when I change tha satellites.xml with reinhard latest,
then I have 0 signal and says 12207 on sport1-cinema1
I don't have sattelites.xml on etc/enigma2
I did manual scan on hotbird with clearing old entries (channel list) and both services appeared on old transponder 11822
Don't have them on 12207
Ok i will clear and mine favorites list and i check again,
Which satellites.xml did you use?
You can find it four posts above, file is attached already - post #71, but I think your problem is not with satellites.xml - it's probably with your channel list
If my Solo2 crashes, which button from RCU can I use to reboot it? I've tried long press on Power Button but didnt worked.
Any idea? I know this is a noob question, but I'm really new with Vu+ machines :)
Thanks
Thanks
If the box crashes, will be automatically restarted the GUI .... what kind of crash do you detect?
@Darian23,
i delete all channel list and then :
with your satellites.xml all is ok when scan hotbird,with vahniball satellites.xml its ok too,
with the reinhard and lyngsat grabber satellites.xml i have problem when i scan hotbird sport1-cinema1 is on 12207 and snr 0.
your satellites.xml where did you find it?
very strange problem....
thank you for your time
