Black Hole Vu+ Solo2 1.7.9-3
Finally i think that a lot users of solo2 have tuner problems,i wish that are software and drivers problems........
Can you be more specific please?
It's because I dont have any problems with my Solo2 and both tuners. Like I said earlier, I can catch very well all week satellites here (also with more signal than my previous receivers).
Hello,
I am newbie in VU+, please help me. Using BH 1.7.9-3 , and Tuner "B" does not work at all. I tried to connect to B-tuner directly with coax without success there is no signal at all, also loop does not work. What should be the reason?
Or... am I so lucky to have hw problem? :wallbash:
Otherwise tuner A is working fine, very nice picture, all is working fine.... my only problem tuner B is not working at all... :fie:
May be I have to send back the equipment to the reseller? Should it be a kind problem until flashing image? :confused:
Many thanks for any useful proposal.
If you have tried swapping over the coax from tuner A to tuner B and then set tuner B the same way as you have had tuner A working and it does not work, then return your box to the seller to be tested as it would seem you might have a faulty unit.
I think that the vu is made new driver at 3/1/13 to fix tuner problem,
Its vu opinion too not only mine.
I've asked about your problem earlier because I'm still using old drivers without any problem! :)
Also... does anybody knows how can I change subtitle size and position on media player??
I think, it is necessery to inform you:
It seems to: my concrete box has "sensitive ghost"...... after reflashing with the same image, same methode (aprox... 5-6th occasion, but I did not count) ...... once upon... like a miracle.... everything is working now. :yahoo:
...basicly I do not understand... :eek:
If you see i have post my problem here in the forum,
I have problem with hotbird and provider netmed ,channel sport1 cinema 1.
I didnt saw it earlier. Sorry.
I've tried those channels and I can catch them :)
I'm using vhannibal channels list.
My Vu+ Solo2 should now arrive sometime next week.
At the moment I have a DM800 with a motorised dish, single LNB and using Motor Positions (not Usals).
Will the setup for the Solo2 be the same as that of the DM800?
He is saying he can receive those channels
Yes now i see it.
With vahniball i am ok too,
With reinhard satellites.xml i have snr 0 and the channels are showing at 12207,
Can someone put reinhard xml and scan hotbird to see if has snr on novacina1 and novasport1?
Yes now i see it.
If you can see with the channel's list I'm using... so... you dont have any problems! :)
You can use the same setup.
Yes now i see it.
Pointless exercise as you have just seen for yourself, the transponders have changed since that satellite.xml was done.
Either use reinhards settings and do a manual scan of the correct transponder, or stick with the vahniball settings as they are working correctly.
I'm encountering similar problems like you. But even with the latest vhannibal settings I'm unable to solve it.
I have 2 other DM800 receivers which are connected on the same Multiswitch and I install the exactly the same settings with Dreamboxedit on all receivers. On the Dreamboxes i'm able to get the channels and on the solo2 I don't!
I'm quiet convinced too that there is a driver issue.
I've configured the tunner A (Configuration = Tuner: loop through to B, B: Normal Tuner Setup)
Now I wonder if I can be watching a HD channel on TV and another HD channel in emu computer via xbmc.
