Black Hole Vu+ Solo2 2.0.5 galaxy
Great guys.
however it still seems that my PC can't stream channels from port 8002. My android phone works just fine with 8002 and vu+ plus app.
any guesses ?
Try to play the stream from 8002 port with Media player classic (about 25sec to open) or Windows media player (about 90sec to open) from your Pc. Don't try Vlc cause the line from transcode ends with the "device=phone" and it can not understand it from a Pc. That is the reason that you can play it easily from a mobile or a tablet.
Unable to Install this image via usb, it hangs on starting after the install reboots, tried redownloading and different sticks. 2.0.2 and 2.0.4 was no problem have no idea whats up with this. anyone had a simular problem? (was no problem reinstalling 2.0.4 after the failed 2.0.5 attempts)
Hi, I was curious to try the HBBTV thing, but on Astra 19.2 RTL HD and VOX HD, nothing happens when pressing the red button?
Press and hold the blue button and then select HbbTV applications from the sub menu.
They don't seem to use a GUI on these 2 channels for HbbTV for some reason.
The Hbbtv plugin is not in the list in long blue menu, and not seen in either plugin or addons download. Hmmmm. Don`t need it, just wanted to try :)
Then it is disabled in the Bh SpeedUp panel, which means it is not installed on your box.
Yes, tried to enable it, save and then restart. Still disabled. Tried to install via Blackhole addon list, download failed.
Is this version stripped down? Where is the opera plugin? Does it come with the Hbbtv-opera?
Do you have an internet connection to our servers ?
If you have enable HBB in
Black HOLE SpeedUp panel.
Then everything will be automatically downloaded from the server.
If you do not have and I think you do not have
check your configuration for network .
The box have net connection.
I also tried to enable miniDLNA just to see what happened there, same thing, goes back to disabled after restart.
Screenshot when I tried to download manually from "Blackhole Feeds plugins"
I know there is net, I also can ping from the Solo2 in telnet to feeds.vuplus-community.net
Thanks for your help, guess I reflash my box.
PLS USE Black HOLE SpeedUp panel to enable or disable image addons and plugins
if you enabled addon is downloaded and installed and if you disabled addon is uninstalled.
Blue>>Blue>>Black Hole Speed up
Hello for all.
I have a new STB SOLO2, I can install Black Hole Vu+ Solo2 2.0.5 galaxy in to new solo2 without other instalation ?
No need drivers o update the solo2 before to install Black Hole Vu+ Solo2 2.0.5 galaxy
Thanks best regards
Hello for all.
Thanks best regards
I think you can.
Hi,
had some problems with BH 2.0.5 on a new Solo2. just I did the stupid mistake to test Openpli beta 4. Now I want to go back to try Blackhole again but the flashing seems ok but the openpli just keep staying there. Any ideas? Factory reset not working. Tried reflashing BH 2.0.5 many times now.
Please help me!
Hi,
Please help me!
Verify if there are some backups into your HDD or into your USB stick and/or remove them.
