Black Hole Vu+ Solo2 2.0.5 galaxy
First of all, thank you guys for your excellent work.
For everyone that is trying to watch stream from port 8002 , in windows, he/she should use either XBMC (with the PVR for VU+ addon enabled) or Potplayer.
Now, the problems that I came across are:
1: In the transcoding stream, there is no option for selecting the Audio Stream. When I choose to watch a stream from port 8002, I can not change the language in audio. To reproduce it, you can try to stream FOX channels in Sky Italia.
2: In the transcoding stream (port 8002), I can not watch channels that are from usb-DVB-T. Despite the fact that I can watch the terrestrial channels, they are not processed in the transcoding.
3: In the transcoding stream (port 8002), I can not watch channels from IPTV. I can see them in my tv, but I can not restream them.
4: I have an OEM usb-Dvb-t (branded as "MAX"), that when I zap fast the terrestrial channels, it stops working and only comes back to life after rebooting the whole system.
5: Finally, the most annoying problem of all. When I watch IPTV channels, if the audio is desynched, I can not synchronise them. The only option is in the global settings and changing it causes all the channels to become desynched.
1) ask directly to Vu+ about that
2) it's known. See my reply nr.1
3) same as reply nr.2
4) it's an AF9015 device and can have too many problems. Open a thread in the dedicated area of this Board about DVB USB devices and drivers
5) same as reply nr.3
Due to solo 2 doesn't support blind scan please add feature to scan +- 10 transponders, because some Russian channels on Sirius and hotbird aren't not found although satellite angles are correct and on correct transponders (where these channels are located) is no quality at all but if manually scan near to the correct transponder these channels are found, don't know why... on another receiver these channels are found on their correct transponders but on solo 2 they aren't. So please make it possible to do kinda software blind scan
who is the name od the default skin on black hole 2.0.2? i have BH 2.0.5 but i love skin BH 2.0.2
Thans
My problem is that after updating to 2.05 neithr plugin suomipoeka 1.01 nor enganced movie list doesn't work. Both appears in plug in menu, but when pressing video-button nothing happens.
Any tips how to solve?
Thank you for this useful information. It was exactly what i was looking for.
Fixes from rev. A are also present in rev. B, right?
I have rev. B but i don't see option for high bitrate on common interface. Maybe options appear only when modul is in CI slot? I still didn't get modul.
Sent from my Nexus 7 using Tapatalk HD
hi. I have vu solo 2 bh 2.0.5. Is there any easy way to see transpoder information while i am on channel list or the only way is to go to menu-> and the last choice for tp info?
After downloaded and test drive 2.0.5 the GUI seem to be more complete and fulfill my basic requirement. and again Solo2 lack of BilndScan feature. Hopefully there's a patch for this utility. Great image anyway. TQ.
Any chance to mod the default MediaPlayer to correctly read subs muxef inside mkv files for the next 2.0.6?
Thanks
Inviato dal mio GT-I9100 con Tapatalk 4
Hello,
there are differences between BH 2.0.5 and BH 2.0.5 Galaxy please?
And what is the best image for Vu Solo2 please?
Thanks
Hello.
There is no option for higher bitrate in the transcoding plugin.
With the new drivers it should work with solo2, right?
