Black Hole Vu+ Solo2 2.1.2
Using Black Hole 2.1.1 my Pinnacle PCTV nanoStick T2 290e has problem switching to T2 channel. Open ATV works without that problem and I'm forced to use it. But I like BH more. Is the problem fixed now?
I'll check that (I hope to still have a -T2 channel in my area)
Thanks for the great job all the team B.H. & a big hug to the family for the loss of Big Ed and Paolino.
  • Like
Reactions: Ev0
grazie, per il lavoro che fate, siete fantastici.
apro explorer per entrare nel decoder tramite web metto indirizzo IP del decoder e mi chiede la password , cosa devo fare, grazie
L'autenticazione di solito è disattivata per default, ma verifica con il plugin OpenWebif nel box se per caso è stata abilitata. In caso affermativo, disabilitala OPPURE metti come utente "root" (senza virgolette) e premi OK
Hello,
thank you for this image.
I have a little problem, I can not record and watch a other channels.
I had the same problem in 2.1.1.
Whereas with other typical image vti it works, but I prefer the Blackhole.
I have two cables on a multi-switch with quattro LNB.
This is not hardware but software.
Thank you in advance for reading.
Hello,
What is your current tuenr configuration?
Hello,
kaikikoo, if you have any emu we cannot speak in this forum. Forbiden.
Good evening, could somebody tell me how to to put a progress bar on movies list, I can't figure how to do it.
I had it installed (Blackhole 2.12) on my vu+solo2 and I put back OpenPli, i'ts a light image but they have it there.
Thanks.
Hi All
I have installed version 2.2.1.2 a few days ago the only problem I have found is a lot of the time when you change channel it does not show up on the LCD front panel on my Solo if you go in to any menu this will show up on the front panel when you exit the menu and go back to any channel they do not show up in the LCD panel did not have this problem on the previous version can any help me to sole this problem or is this a bug issue.
Thanks
T2/hd Working as earlier here in BH but a little lower SNR than T/sd
