Black Hole Vu+ Solo2 2.1.2
Black Hole 2.1.2​
"This release is dedicated to our friends that are sadly no longer with us Paolino and BigEd"​
What is new:
  • New skin MX Black Speed P
  • Duo2 drivers: fix dual DVB-T2/C tuner in changing mode
  • Update languages: es, no
  • Updated MediaTree (all dvb usb drivers)
  • Updated OpenWebIf
  • [hbbtv] Update and fix crash
  • [ScanSetup] Support TT3L10 automatic scan.
  • [TransCodingSetup] fix set config bug and wrong description.
  • [ScanSetup] dvb-t2 channel should be searched using scan app. & fix typo.
  • fix vuplus-blindscan-utils
  • Support dual DVB-T2/C Tuner automatic scan
  • Adjust bmem in duo/solo
    - To support 1080 FB
  • update drivers
    20141021
    - Support 1080 Framebuffer(duo/solo need kernel update)
    - Support Dual DVB-T2/C Tuner(uno, ultimo, duo2)
    - Support 4 vtuners(solose, vtuner is mutually exclusive with transcoding)
  • Added rtl8812au driver to the image (DWA.182 Rev A1 dongle works GREAT!)
  • Added isofs module in images with kernel 3.9.x are always compiled as a module (M)
  • [rt3070] added support for DWA-140 rev D1 (experimental)
  • Fix WOL problem in duo2
  • update drivers
    20140925(duo2, solo2, solose)
    - Fix HDMI problem in some AV receivers
    - Fix WOL problem(duo2)
    - Fix AGC/SNR display(SSH108)
    - Fix misc bugs.
  • [rtl8812au] changed drivers from Edimax to GitHub
  • [rtl8188eu] Updated driver to the last commit available
  • Update driver
    20140829(solo2, solose)
    - Fix transcoding problem(solo2, solose)
    - Optimize memory usage(solo2)
  • [vuplus-webmanual] fix incorrect output for solose.
  • update drivers
    20140808(duo2, solose, uno, ultimo)
    - Improve DVB-C/T(CXD1978) tuning performance
  • fix uno/ultimo harddisk detection
  • fix slow network
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Black Hole 2.1.2​
What is new:
  • Updated OpenWebIf
  • update drivers
    20141021
  • update drivers
    - Fix misc bugs.
  • Update driver
  • update drivers
  • fix slow network
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
Thanks great image
Hello. I installed the 2.1.2 version of blackhole. but I had a big problem:
- When I press once a botton on the remote as (ok - Exit ....) the botton does its job
- But when I press the botton even two or three times the botton does not work. I have to press another botton.
results can not I enter my wifi key. for example. for the letter 'T'. must press 8 five times. but. it crashes in the first clik.
I hope you understand my problem.
Good afternoon, could somebody tell me how to to put a progress bar on movies list, I can't figure how to do it.
I had it installed (Blackhole 2.12) on my vu+solo2 and I put back OpenPli, i'ts a light image but they have it there.Is there someone who could help, or there is no movies progress bar on Blackhole 2.12?
Thanks.
T2/hd Working as earlier here in BH but a little lower SNR than T/sd
Thank you for replay. My problem is, that with BH image this T2 stick switches to T2 channel wery, wery long time, sometimes not at all. With Open ATV image it works without big problems.
Good evening, I think, maybe nobody knows about my question I would like very much to have my movies status progress bar, but as nobody helps me I think there is not this possibility on Blackhole .
Thankyou anyway.
I hope my English is good enough, this time and I wouldn't be corrected .
