Black Hole Vu+ Solo2 2.1.2
return bh 2.10 pip channel zap crypt still do not function
Thanks for this realise but same problem with pip crypt channel zap and watching crypt channel when i'm record an other channel.
It's the first time i use BlackHole, i just had my Solo2 ;-)
Good evening, I think, maybe nobody knows about my question I would like very much to have my movies status progress bar, but as nobody helps me I think there is not this possibility on Blackhole .
Thankyou anyway.
I hope my English is good enough, this time and I wouldn't be corrected .
The progress bar status already exists in Movie list and movie player used in BH image .
Movie Progress bar.
The same in Media player .All if you using orginal BH movie list and players.
So I do not understand your question.
First of all thank you to the team for the amazing work. I never even had the desire to try a different image. Now i ve got a few questions as a newbie...
1) I searched for many satellites and when i reached to 42east Turksat i was not able to set a predefined transponder on Motor adjustment screen. My solo2 turned green and rebooted..! Is this a general bug or is it me??
2) I remember in my Humax 5410z(i think) when searching for a satellite on the motor rotation screen you could see a channel playing when the signal was good. Why isnt that possible on recent receivers and images? It would help a lot to pick a channel and then turn the motor until you get a picture. Unfortunately signal meter isnt always reliable.
3) Is there a pinned list with the wifi sticks that work 100% with the black hole image? I have found a list but its for a different image and i guess every team includes its own driver selection right?
Regards
Nikos
Thanks a lot for your great work!
I have a problem with this image: even if I watch a free channel every 40sec/1min there is a black out for 1 sec and then it works again correctly.
The same problem when I use the Nova-T Stick (DVB-T).
I reinstall the image several times but the problem still remains.
Any idea ?
Thanks a lot
I have a Vu+ Solo2 with a OCZ SSD 60Gb.
Also the BH EPG needs work. It should have an option to globally set an automatic download time. Not to every single provider. Also every time you want to disable automatic download from a provider you have to restart enigma... imagine doing that for 15 providers...
Regards
Nikos
1) post here the crashlog
2) the rotation screen takes priority on tuner and it's clear that the box cannot use it to tune a channel
3) It's hard to prepare a list .... do you have already a wifi dongle in your house?
great job, once again..
is there any chance we might see an option to save timeshift as a movie?? that would be great!!!
Hi,
Fantastic software so don't worry but I do have a suggestion.
When you notice a series of tv programmes, say weekly for 6 weeks this causes a problem. I have never got any series link or similar to work so its back to basics.
When in 'timer entry' you have 'repeat type' consisting of once or repeated. When repeated is selected it really could do with the option to select, for instance, start date and finishing date when you select weekly or when selecting 'weekly' it asks for how many weeks. This way a set number of programmes can be recorded.
At the moment, I have to set a reminder on my phone to turn off the weekly timer in a few weeks!
Is this an option?
Thanks
Black Hole 2.1.2​
"This release is dedicated to our friends that are sadly no longer with us Paolino and BigEd"​
What is new:
  • New skin MX Black Speed P
  • Duo2 drivers: fix dual DVB-T2/C tuner in changing mode
  • Update languages: es, no
  • Updated MediaTree (all dvb usb drivers)
  • Updated OpenWebIf
  • [hbbtv] Update and fix crash
  • [ScanSetup] Support TT3L10 automatic scan.
  • [TransCodingSetup] fix set config bug and wrong description.
  • [ScanSetup] dvb-t2 channel should be searched using scan app. & fix typo.
  • fix vuplus-blindscan-utils
  • Support dual DVB-T2/C Tuner automatic scan
  • Adjust bmem in duo/solo
    - To support 1080 FB
  • update drivers
    20141021
    - Support 1080 Framebuffer(duo/solo need kernel update)
    - Support Dual DVB-T2/C Tuner(uno, ultimo, duo2)
    - Support 4 vtuners(solose, vtuner is mutually exclusive with transcoding)
  • Added rtl8812au driver to the image (DWA.182 Rev A1 dongle works GREAT!)
  • Added isofs module in images with kernel 3.9.x are always compiled as a module (M)
  • [rt3070] added support for DWA-140 rev D1 (experimental)
  • Fix WOL problem in duo2
  • update drivers
    20140925(duo2, solo2, solose)
    - Fix HDMI problem in some AV receivers
    - Fix WOL problem(duo2)
    - Fix AGC/SNR display(SSH108)
    - Fix misc bugs.
  • [rtl8812au] changed drivers from Edimax to GitHub
  • [rtl8188eu] Updated driver to the last commit available
  • Update driver
    20140829(solo2, solose)
    - Fix transcoding problem(solo2, solose)
    - Optimize memory usage(solo2)
  • [vuplus-webmanual] fix incorrect output for solose.
  • update drivers
    20140808(duo2, solose, uno, ultimo)
    - Improve DVB-C/T(CXD1978) tuning performance
  • fix uno/ultimo harddisk detection
  • fix slow network
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thank you!
Any idea ?
Thanks a lot
I had this problem, because my adsl TV box was on when watching vu+ solo2. May be Hdmi conflict ?
