Black Hole Vu+ Solo2 2.1.3
hi 2 problems i found
1.usb dvb-t stick bitrate show like version bh 2.0.9 (no stable 70% go 38% and 51%) bh 2.10 2.11 version play excellent..
2.picture in my samsung 3d tv lost brightness and litle blurred ..
1. what dvb-t stick do you use?
Hi there, i'm having issues getting this image to flash to my box. I have the Vu+ solo2 with BH 2.0.8 at the mo.
I'm trying the usual flash method with usb stick in the front of the box, it reads the usb, flashes and reboots but i then get stuck on the BH boot logo screen on my tv and on the front of the box it sticks on "starting" . Pressing buttons on the remote doesn't do anything at all and i have to reflash an older version to get the box to start up again. Has anyone any ideas to solve this? Thanks in advance and thanks to the BH team for your efforts!
Seems you have a clone box.
If your box is TRULY genuine, flash image in sequence from 2.0.9 to 2.1.3.
I don't think it's a clone box i bought from WOS which i though was a place that was ok to buy from! Hope so anyway. I've had the box since dec 2013 and its worked fine since then n it worked with BH 2.0.8. Thanks for the reply anyway. I'll try what you suggested.
Salve this immagine in Oggetto ettari dei Problemi.
1 Funge il volume non il non ti da la possibilita di Alzare o abbassare l'audio e neanche di mettere muto.
2 SE VUOI registrare Una Trasmissione non Commuta il tuner e non ti da la possibilita di VEDERE UN'ALTRA trasmmissione shermo nero SIA in sat Che in digitale terrestre.
Del resto e Una bella immagine ma SI DEVE Risolvere questi piccoli inconvenienti.
Saluti a Tutti e grazie mille!
You are in the INTERNATIONAL SECTION SO ONLY ENGLISH IS ALLOWED.
Read the following post: http://www.vuplus-community.net/board/threads/problema-configurazione-tuner.19718/#post-150128 about your "issue".
Did you pull out the USB stick after flash ?
Some USB sticks can cause a problem
also in normal use but also in the new image flash.
Always try with different USB stick.
