Black Hole Vu+ Solo2 2.1.3
Dear All,
Is it possible to disable or remove the blindscan module? I several times tried but unfortunately it is impossible to remove or disable it. It automatically adds some unwanted satellite channels every time.
In this version the external plugin Kartina.tv is not working. I went back to the 2.1.2 version. Does someone know what to do to make this plugin working in 2.1.3? Of another plugin to let Kartina.tv working?
No backup images are supported here. Flash with clean BH 2.1.3 and customize it as you want.
the image look's great.
My biggest concern is still that after testing Transcoding (play may box on my apple iPhad or Iphone) there are still lot of connectivity lost and crashing.
Image 2.0.5 was one of the best on that direction.
Regards
I'm a Balck Hole lover.:notworthy:
Downloading now and test tonight.
The skin seems to be great :rolleyes:
Will report later, enjoy testing! :victory:
I am using the same plug-in on 2.1.2. News?
Black Hole 2.1.3 Universal Meoboot​
  • MeoBoot updated and now compatible with all major images
  • New Army skin DarkSky
  • New fade effect in osd
  • OpenWebIf updated and added Italian translation
  • Httpstream updated:
    - added chunked transfer support.
    - connect to TS stream in seperate thread.
    - add basic http authentication support.
    - add redirect and playlist support.
  • Elistbox: add setFont function (workaround for Full Hd skins)
  • media-tree rebuilded module list
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
thanks for the jobs B.H. !!!!!!!!
Regards
Hello. Have you remembered to setup Port Forwarding in your router on port 80 and port 8001 ?
Hi There,
yes, all this was done, I am streaming for a while to my private iPhone, eg. v2.0.5 was also one of the best
PS: I am using a different port for streaming witch was working flowerless with the old images. Also port I believe the 8002 is better for stream still your suggestions are greatly appreciated.
The 2..1.3 is also streaming, the problem is that is braking up non stop transmission.
Regards.
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
its seems to be very stable however here is my problem: my solo2 uses wireless adapter which i found more stable than power line adapters. I use C**am 2.3.0 because any other c**am version won't read my sly card!!! If i use BH 2.10 and say c**am 2.1.4 it reads the card yes but it drops connection and causes freezing. on BH 2.1.3 it works perfectly as a client but not good at al as a server. on C**am 2.3.0 my own card freezes!!!
any ideas? help? solution?
No emu support here.
You haven't read our Board rules so you win a week ban.
