Black Hole Vu+ Solo2 2.1.3
Can you tell me if is compatibile with VU+ SOLO2 clone? I don't want brick my box again I did 2x by wrong image. Can you tell me step by step how to flash this new image and not brick this flash chip? Thank you
BH SUPORT ONLY ORGINAL BOX !!!!!!
NEXT time buy ORGINAL BOX !!!!!
hello friends
i have black hole image 2.1.3
but i have a problem
i cant do mebbot and i cant install openpli on the black hole
my base image is blackhole and i want install openpli or vti on the black hole with meboot
but when i install meboot and put the image in Mbootupload on the DCC
when i want install second image
it does not install
plaese help me to install second image
please put full guide or full help for mebboot plugin
thanks
bye
Hi, Can this image be installed via software update or does it require a usb flash
Thanks in advance.....Geoff
dears
thanks at the first
i had a problem after updating to 2.1.3 in channel changing. i had one dish with motor (LNB 2)and one fixed dish (LNB 1)that they goes to one 4-1 switch and one cable comes to tuner A.
WHIT THIS update when i changed the channel to LNB 1(FIX DISH )AFTER THAT i changed to motor dish(lnb 2 ) the motor sign will showed on the screen and i haven't access to any channel.
pls help.
