Black Hole Vu+ Solo2 2.1.4
pleas i have wifi problem it can see the sidd and i put the corect pass but it refus to
conect i try dhcp make it activ to obtain dns otumaticly i reboot but no way my solo is original - sorry for my bad ing
It seems that you are going from bad to worst, i was using VTi, come back to Black Hole due to 2.1.3 Image very happy with that one, but 2.1.4 is Terrible, i think done with you, i will install VTI again, bye!!!
If you were happy with 2.1.3 you still can go back to it. I'm happy with 2.1.3 and for the time being don't feel that I should change it. No one is obliged to change the image and stay with it every time that there is a new one.
Thanks B H - a great job as usual.
I have a question
I restore my personal settings but settings for crossepg are set to default and not mine.
Am I doing something wrong?
Can someone please test if Media Player forwarding a movie with key '9' in remote still lags/crash in this version ?
Thank you. :)
Hi:
I installed 2.1.4 yesterday... I found two big defects:
- Sometimes, in standby, I can not power on with remote (by ssh I can enter and reboot, the STB is alive).
- Youtube is slow like hell.
- When I program something, it is difficult to write with the remote the keypress of a number (3rd mainly) it is difficult to get (example: I want a "i" and I get a "h"... many times).
The rest seem to work... I always wanted I more complete media player (easier movement in the directories to play any file)... but thanks,
Xostia
Hi:
Xostia
Have you tried to change your remote batteries?
Hi:
Xostia
Try EMC plugin from feed .
Maybe will be good for you and this whot you loking.
Thank for this image, but today my channel list has been deleted.
Some in my Vu Ultimo with 2.1.4.
Regards.
