Black Hole Vu+ Solo2 2.1.4
Thank for this image, but today my channel list has been deleted.
Some in my Vu Ultimo with 2.1.4.
Regards.
Surely you have a problem with your settings.
You can download new settings or you can make a full channels search.
My settings are ok with 2.1.0.
With 2.1.3 or 2.1.4 my list disappears after a few hours
Regards.
Im never see problem with chanell list on all version whot you write i have one list more 3 months on one from my box.
Maybe your setting delete plugin who was installed by you or you have real error in setup image.
Really excellent work!!
Upgrade was very easy, and personal backup was restored in minutes without any hassle.
I really like the new HD skin, I wish it could be transparent though.
What's great is that it supports Right-to-Left languages like Arabic and Hebrew , which is a problem with most other skins
Keep it up!!!
Hi,
I'm also having issue with channel list. Since ver. 2.0.9 I usually load my DTV channel and then set vhannibal autosetting to motor autoupdate to void overwriting dtv ch list. Everything was fine till 2.1.3.
Now with 2.1.4 DTV list were deleted (DTV could not be excluded in favourite). Tested right now because vhannibal release new channel few minutes ago.
I will test better by the way and report back.
Cheers my friends.
Hi, nice image as always, just a question I have found youporn plugin like default, I'd like to remove it but is not in remove panel menu, of course I can remove it
deleting the plugin in python but I thin is better don't put plugin like this in default mode thank you
Are you serious ?, we don't include this plugin with the image, if it is on your box you have installed it yourself.
I don't remember to have installed it, so I try to make a new fresh install formatting my usb stick and without using a personal backup thank anyway
Remember is no good way used very old personal backup on last version image becouse in all image is something changed . And if you used backup from version 2.0.9 will be alot problem best way is used backup on next 2-3 relase and next time made new on image setup from begined.
The channel are correct in the deco but If I access by OpenWebif there are not channel (I selected Current, List etc.) . I use Explorer ver. 11 with winddows 8.1.
Black Hole 2.1.4​
What is new in Black Hole 2.1.4:
All models: Full HD Skin ready.
The 1920x1080 framebuffer support recently introduced in Vu+ drivers has made it possible to use full hd skins. But many parts of the enigma2 gui are hardcoded with fixed fonts and itemheight.
This causes fonts at 1920x1080 resolution to appear far too small. All these gui parts have been re-coded in Bh 2.1.4 to support larger fonts and itemheight in case of full hd skins (thx to Matrix10)
Solo and Duo only:
The 1920x1080 framebuffer support has required extra Ram usage. For this reason the old Solo and Duo models do not have enough free ram to run the curent images with these new features.
In Black Hole 2.1.4 we have included ram compression (zram) that increases performance by avoiding paging to disk and using a compressed block device in RAM instead, inside which the paging takes place until it is necessary to use the swap space on a hard drive or usb stick. Since using ZRAM is an alternative way to provide swapping on RAM, zram allows Linux to make more use of RAM when swapping/paging is required.
misc:
  • drivers:
    201412005(zero, solose)
    - Improve PQ(zero)
    - Adjust LED brightness(solose, zero)
  • update driver
    20141201(solose)
    - Fix analog audio(solose)
  • drivers: 20141126(solose, zero)
    - Fix booting problem(solose)
    - Support LED brightness control in idle mode(solose)
    - Support LED brightness control in normal/idle(zero)
    - (Brightness can be controlled in Menu -> Setup -> System -> Display Setup)
  • New Skin MX-Black
  • Meoboot update: Fixed the issue of non working usb drivers in images in multiboot.
  • About screen: Add drivers version, kernel version and Cpu info.
  • Bh Full Backup update.
  • OpenWebInterface update.
  • WirelessLanSetup: add quote to wpa_passphrase for password.
  • Black Hole Swap panel: Allow to create swap files upto 2 GB.
  • Black Hole Swap panel: Update descriptions (Thx to Ev0).
  • Solo2: fix ethernet problem in some Gigabit switches.
  • Solo/Duo: implement Zram
  • Librtmp update.
  • Added to feed: livestreamer, livestreamersrv
  • Added to feed: python-mechanize python-futures python-pip python-requests python-singledispatch
  • [PATready] 'cnt' is increased twice, causing failure to obtain a single pmtpid.
  • [VirtualKeyboard] fix default layout (en) must be "qwerty"
  • Bh Device Panel: fix meoboot mointpoint only when meoboot is installed
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thanks,
Merry christmass to all team
Best regards
