Black Hole Vu+ Solo2 2.1.5
Have a problem with this version that the picture hangs, change channel and then it works for 2-5 minutes. Just wonder if that could be error on software or Diseq-switch...
Black Hole 2.1.5​
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thank you very much
Black Hole 2.1.5​
  • fix keymap bug
  • fix channel skip
  • update Usbtuner
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own
ddamir subs plugin crashes more than a month now.Is there a problem with the plugin ?
i upload a crashlog if someone can help.
The error is:
  File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
    res = self.actions[action]()
  File "/usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/plugin.py", line 1104, in Gotovo
  File "/usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/plugin.py", line 1058, in prevod
  File "/usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/plugin.py", line 1118, in prevedi
  File "/usr/lib/python2.7/urllib2.py", line 126, in urlopen
    return _opener.open(url, data, timeout)
  File "/usr/lib/python2.7/urllib2.py", line 400, in open
    response = meth(req, response)
  File "/usr/lib/python2.7/urllib2.py", line 513, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/lib/python2.7/urllib2.py", line 432, in error
    result = self._call_chain(*args)
  File "/usr/lib/python2.7/urllib2.py", line 372, in _call_chain
    result = func(*args)
  File "/usr/lib/python2.7/urllib2.py", line 619, in http_error_302
    return self.parent.open(new, timeout=req.timeout)
  File "/usr/lib/python2.7/urllib2.py", line 438, in error
    return self._call_chain(*args)
  File "/usr/lib/python2.7/urllib2.py", line 521, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 503: Service Unavailable
HTTP Error 503 ... so I suppose there is some problems with DDamir server
