Black Hole Vu+ Solo2 2.1.5
Hello.Just installed OpenATV to try some IPTV,and when i want to go back to blackhole,fresh install i can't pass BlackHole Speed Up.
Remains with retrieving data...And that circle on the right corner.
It's the feed down or i have problems with my STB ?
First of all, let me appreciate your great efforts developing images for our boxes.
Two questions:
1. Does this XBMC on the box support playing blu-ray iso files?
2. What is your estimation for the date of releasing 2.1.6 version?
Best Lock
Two questions:
Best Lock
1. I think not yet
2. No ETA.
can someone tell me what is opengl image ? iwant to use black hole in flash and then with meoboot other images.
first think iwant to know is if i can use satdreamgr and openpli in meoboot with bh215 in flash.
Abd second where to install meoboot? I used to format a usb for flash and universes .Can i still install meoboot in this formated flash or i have to format a different usb exclusively for meoboot?
My flash in Solo2 is maxed out and showing 100%, does anyone else has this problem or just me.
Can anyone please point to any solution for it?
Is the xbmc used through your flash or on hdd?
I'm kind of new to XBMC, I've checked it there is folder called XBMC in External HDD so I'm not really sure how I'm using it but I will have a look at the link to see if I could get it sorted.
P.S. Problem with B.H 2.1.5 is that this HD often gets uncounted and after every re-start you have to manually mount it again.
Are you doing the mounting through device manager? Is it a usb or internal hdd?
