Black Hole Vu+ Solo2 2.1.5
Hi Guys the new Image is great and feels really fast! Thank you.
Having trouble mounting my external usb hard drive ,I usually mount it as /medida/HDD as I've never bothered with an internal drive.
I can see it and access files through media player no problem. When i try mount it restarts as normal but still showing as not mapped? I also can't see the drive in XBMC file browser.
I have two 16gb sticks in the back mounted /media/usb and /universe with no problems.
Thank you.
TMG
Try formatting drive on pc as fat32 then remap
HI Gimitryci
I've been using this drive for 2 years with solo2 with no problems.
I don't think(Hope its not) its a formatting issue as I've a lot of data saved on it.
This issue only arose after install 2.1.5.
Thanks
HI Gimitryci
Thanks
Ok. To test the drive is error free get it connected to pc and tested with free trial program hdd sentinel.
Black Hole 2.1.5​
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thanks to you for another great image!!!!!!!!!!!!!!!!!!!!!!!!!!
hello,
i have installed the new image in my solo2 but if i want enter in ftp with DCC they give me a message ( Bootmanager: not found. )
please help!
Peace
hello,
please help!
Peace
you need to logon as root and password blank then click telnet and type in this command
passwd
This is the unix code to change password however you may get a message that says retype password before even submotting the new password just hit enter and run the passwd command again this time you will be able to enter a new password and confirm it
Then logon to dcc as root and the password you have created the bootmanager message should be disreagrded
hope this helps
passwd
hope this helps
Ok i will try !
When i press the teletexte button i can't exit from it
so i have to reboot my decoder from the rear button to solve the problem.
Hello,
i have big problem with image 2.1.5...i have downloaded some picons, themes and plugins but after restart it sticks to the screen of starting guin and does not booting..Is this an issue of a theme or picon ??? How can i delete with ftp all the picons and themes i have downloaded ??
Hello,
Fresh image installation safest option on my opinion
