Black Hole Vu+ Solo2 2.1.5
I add the channel to the bouquets with dreamboxedit and everything is working perfectly
Regards
Enviado desde mi GT-I9505 mediante Tapatalk
Hi Guys
I have installed the BH 2.1.5 in flash.
Can I install the same image in meoboot (as I used to do in previous/old BH images) - media/usb where I can add more addons/picons/plugins...etc inorder not to load the receiver flash memory.
Thanks
Supermario
Hi Guys
Can someone please let me know if I can use proxy as certain sites are blocked in the Country I work and live. I am using BH 2.1.5. I want to use this proxy specially for Xbmc movies/Adult stuff :)
Tks for the assistance.
B/Rgds
Supermario
:thanks: @angelofsky1980 for your quick reply.
Really good image and thank you very much, but i have problem with mounting my Seagate 3TB external hard drive. Is there someone have the same problem ?
Have you tried using vucc? You can do mounting and storage sorting from there. Not sure it will sorted but worth trying
the same problem silicon power 500GB
Same problem with my nas server. Something went wrong with this image when it comes to mounting network drives. I have been using this nas with blackhole for 2 years and i had no problems before.
I've mounted my NAS NFS shares (2 shares) as usual. No problems detected. Last night I've seen some media content stored without problems.
with this new image BH
has solved the problem of record one channel and watch another channel??
thank you very much to the team BH
Weakly image.
Poor quality on SD channels, worse on HD,
Don't working permanent timshift in mode auto (on 2.1.3 worked perfectly),
Don't working CrossEPG on sifteam servers.
Please admin to move posts about thanks and greats to new forum's thread.
Weakly image.
I don't know what image are you using but my 2.1.5 on Solo2 works GREAT on both HD and SD channels.
I don't use PTS and you should check if there is a newer version for that plugin
CrossEPG with @CloudItaly howto works great without issues. If you take a look on the forum you can read some posts about CrossEPG problems and related solution. I'll remember you that CrossEPG is a simple addon. The problem is related to external servers not related to BH images.
Sorry but i see worse quality in 2.1.5 (look for post 127 and Your answer)
Only one PTS version: final 1.0 from Blackhole addons worked properly to 2.1.3 image (my last). Unfortunately for my wife PTS is main addon.
I manual edited CrossEPG list providers and its finaly working.
I've read the post and the reply you mention... Have you reported this issue to Vu+?
Hi Guys the new Image is great and feels really fast! Thank you.
Having trouble mounting my external usb hard drive ,I usually mount it as /medida/HDD as I've never bothered with an internal drive.
I can see it and access files through media player no problem. When i try mount it restarts as normal but still showing as not mapped? I also can't see the drive in XBMC file browser.
I have two 16gb sticks in the back mounted /media/usb and /universe with no problems.
Thank you.
TMG
