Black Hole Vu+ Solo2 2.1.5
many people here like this version without even test it , its so so bad version, so bad qualty , crashing with iptv userbouquet , channel list smaller , so bad version from black hole team
In future I suggest you tell the black hole team you settings so that they can work around your settings/plug-gins and addons
BTW: I have tested \Image and I can honestly say GREAT IMAGE!
no i dont tell them in future any thing if you like this version then enjoy with it forever and dont change it !!!! you are so loyalty
:D
Solution for you is simple
use the old image and do not change in the next hundred years.
IPTV does not work with the new image , not due to the BH team changes
but because of the image changes implemented by VU + (OpenGL,new drivers e.t.c)
Always appear some users like you
who have negative comments after each change
It was the same with the transition from Enigma1 to Enigma2
it was the same with the change from OE OE 1.6 to 2.0, etc.
Besides everything you wrote is not true
except IPTV.
My image is not collapsing and the list is excellent
as before.
Provided not to use plugins and the like that are not good for these new images. Image works very well
and will be in the future even better.
But you promise me you're staying at the old image the next hundred years. :help:
Hi Guys the new Image is great and feels really fast! Thank you.
Having trouble mounting my external usb hard drive ,I usually mount it as HDD as I've never bothered with an internal drive.
I can see it and access files through media player no problem. When i try mount it restarts as normal but still showing as not mapped? I also can't see the drive in XBMC file browser.
Thank you.
TMG
Hi Blackhole Team
I have an idea for your next image, why not create a sound effect when using the animation menu.
Whilst selecting on the Menu button and selecting any sub directory there should be a unique sound effect to it.
What do you think? Can it be done?
Would make a great collaboration to the animation menu.
Thanks
:D
except IPTV.
as before.
now i have 2.0.4 its perfect for me
and if this image 2.1.5 perfect black hole dont need to make new version and say fixing it and it ........etc
can you promise me too you will have it for just one year :yahoo:
if you do i will do :thankyou:
Can you explain to me why IPTV is working in OpenPLI and VTI and not in Black Hole latest image?
It is because we use the latest VU +coding.
IPTV works in BH 2.1.4 older image.
So for IPTV you can use the older image until the problem solved in the newer image coding.
Pli is partially different story
they use in the whole image its own modifications.
We remain on the original VU +coding
it has pluses and minuses but the same rules are for other images.
Your choice.
My choice is not difficult ...
Because I know very well the pros and cons.
Who loves clean fast image with nice graphics and clear fonts/letters to be known BH.
Most problems in BH 2.1.5 come from not Complementary addons/plugins/skins,etc
that users added.
And not because of the image as it is clean then it works very well.
With the exception of IPTV.
Experienced BH users know it well they are with us for many years.
From media player i can not see greek subtitles. The subs are utf-8 encoding and it worked fine with older image. Will there be a fix for that.
Except that small problem for me, the new image is great. Thanks
hello, with version 2.1.5 My Solo2 just by installing it and adding some satellites and 2 to 3 plugins , flash memory is full, I suggest you make a version without plugins and leave the choice to the user install what he wants , so he will have some memory , There are another problem , I can not have suuprimer plugins from the image server, thank you to settle the problem
You can use BH Speedup function to remove unnecessary plugins.
