Black Hole Vu+ SoloSE 2.1.5
lorenzo64
Black Hole 2.1.5
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.1.5-vusolose_usb.zip
Matrix10
INFO About skins
IN HQ Skins you use Picon FORMAT 220 x 132 .You can find on BH image Download Server.
On the server you can also find HQ skins with different colors dark and white.
In this image you can also use old skins but not with picon format 220 x 132 most with
picon format 100 x 60 .
In HQ skins you can only use plugins with coding support for 1920 x 1080 format
Otherwise panels will be small.
Except for Enhanced Movie Center
which is coded within some HQ skins from our image server and then you can use.
If you use MediaPortal with HQ skins format 1920 x 1080 then you can only use the versions from our BH image Server.
Search40
I have VTI installed at the moment, if i backup settings, can i try this image, and do restore from VTI to Black Hole????
Search40
This image is full of CRAP, wasted my time with this, i give you very Clear Advise, try to do something good not CRAP like this, bbbbbbbbbbhhhhhhhhhhhhh!!!!!!
angelofsky1980
BlackHole Driver Specialist
LOL. You are crazy.
You are wasting OUR time.
If you have something useful post it or SHUT UP.
angelofsky1980
Just Honest with you like it or not, not crazy at all, lot of other people will say the same, just wait Little!!!
If there are people who have something to be unhappy they can post here without problems.
if you have something useful to report, you are welcome here... if you haven't SHUT UP.
Search40
I do not like the Image, there is not something to report, do not use this word SHUT UP it is very Rude, i can express my opinion here as i like without offending any one!!!
angelofsky1980
Expose your opinion is absolutely correct but report as CRAP because YOU don't like it it's not welcome.
If you don't like this image, DON'T USE IT. Other people likes it and they uses it happly.
  • Like
Reactions: Ev0
Ev0
Admin
Yes you are correct it is rude to tell someone to SHUT UP.
However it is even more rude to say that an image is CRAP and you wasted your time with this, just because you do not like it.
Nobody forced you to use the image, so if you do not like it and you feel that you wasted your time, thats your problem not ours.
The only rude person here is YOU!!!
dave3dg
To communicate by correspondence on forums requires a degree of skill due to the unemotional aspect and single dimensional portrayal of any comments made.
Words should be chosen carefully as even innocent phrases can be taken the wrong way and very often cannot be withdrawn or deleted.
Using anger and offence in threads is totally inappropriate as most of us are at least of average intelligence and are bewildered as to why such an ungrateful person should make such comments.
I personally am very grateful to the team for providing us all with an all-round good free product.
Many thanks team for your efforts.
