Black Hole Vu+ SoloSE 2.1.5
Hello Matrix10.
Ok thank you for help. With the L4L i will wait for next Update. Now is not for me the best way.
And for the other problem. In Solo SE this point is not available. On my Duo2 is there. You really mean SoloSE?
I´m sure there is not . I have searching for. I can´t find it sorry.
System Menu >> Recording paths >> Make choose >>on SoloSE is not available.
Greetings Pyromon
I think you can install LCD4Linux
1. You have to copy Lcd4Linux ipk file to /tmp
2.with/in telnet or DCC command>>>
opkg install -force-downgrade /tmp/*.ipk
3. RESTART BOX
3. RESTART BOX
@Matrix10
here the result to install with telnet:
command: opkg install -force-downgrade /tmp/*.ipk
root@vusolose:~# opkg install -force-downgrade /tmp/*.ipk
Installing enigma2-plugin-extensions-lcd4linux (4.5-r4) to root...
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enig
a2-plugin-extensions-lcd4linux:
* python-imaging * python-mutagen *
* opkg_install_cmd: Cannot install package enigma2-plugin-extensions-lcd4linux
root@vusolose:~#
@Matrix10
Collected errors:
root@vusolose:~#
I have to test .
I have to test .
@Matrix10
Collected errors:
root@vusolose:~#
1. telnet
command :
opkg update python-mutagen
2. telnet command :
opkg update python-imaging
3. install with telnet Lcd4Linux ipk
or copu Lcd4Linux ipk file to /tmp and install
with BH Addons Manager >>Manual Install Ipk packages
1. telnet
command :
2. telnet command :
@Matrix10
thank you for help. I give you later feedback.
Greetings Pyromon
1. telnet
command :
2. telnet command :
Hi Matrix10,
so tried it again . I have installed so you said.
I can´t install the L4L. Is the same result .
Collected errors:
root@vusolose:~#
Greetings Pyromon
Hi Matrix10,
Collected errors:
root@vusolose:~#
Greetings Pyromon
Why would you want L4L on soloSE ? It does not have an Lcd display.
Hello Artorious,
You're absolutely right. I have 2x Samsung SPF 107H in use. At the Duo2 and the SoloSe. So I can see all the information. This is convenient for me. Only I have the problem that when it absolutely BH 2.1.5 at the SoloSe does not work (can not install L4L) and just as the SoloSE has no display, it makes sense the Samsung display used to have because it is also very large.
Hi Matrix10,
Collected errors:
root@vusolose:~#
Greetings Pyromon
OK
This must work .I have installed my self.
1. telnet
command :
if necessary also command : opkg update python-imaging)
2. copy python-imaging_1.1.7-r4_mips32el.ipk file to /tmp and install
3. copy Lcd4Linux ipk file to /tmp and install
(Install with BH Addons Manager >>Manual Install Ipk packages)
Cannot mount my HDD or USB stick on 2.1.5. Once I initialize/format these, from tne blue pannel I set media/hdd and media/usb, restart... but when I go to the blu pannel again, it shows these are still not mapped.
I do not have any issues with 2.1.4 regarding this and that's why I downgraded.
