Black Hole Vu+ SoloSE 2.1.5
To stop at this
We do not like conflicts here and unnecessary discussions.
Sometimes I have the feeling that we are obliged to someone something.
But that's not true.
People give a lot of their free time to have a good image.
On the other hand some People keep repeating the same story.
Agn and agn with any main change in Enigma coding
When moving to a higher level software OE 1.6 >> OE 2.0 >> OpenGL
problems arise such as not Complementary plugins
Starting problems with the driver, skin coding and the like
But in the end we get a better result and even better image
I would say without change there is no progress.
I think this image is between 2.14 and Beta 02, in my Opinion should have been called Beta......Something, this does not mean that me and other people criticizing this image, are not thankful to Black Hole and other Teams that provide this images, this is very complicated technology, and is done by very clever people, i was very happy with Black Hole 2.13, after that i was not happy with the rest of images coming, I sell Satellite Receivers and i have tested all kind of them, I have passion about this, the reason i use Vu+ Products is because i think they are very good, now i can write all the reason why i was not happy with this, but i keep that for myself, as it will take me long time, I hope better in the future!!!!
Now it is even less clear.
So if you were happy with BH 2.1.3 why you changed image
or better to say why you do not use the BH 2.1.3 if you're not happy with new images.
To add
I think something basic you did not understand.
Enigma receivers are hobby receivers (not necessarily if you use all the time same image that works well)
But if you use it as a hobby that means that you have a permanent beta image
which is constantly evolving to some extent
and then you switch to a higher grade but also problems that all involved in the project need to solve.
But if you do not want you can use old image.
hi,
when i try to launch xbmc, i get a black screen and the only option is to hard shutdown an reboot. i've missed something about xbmc configuration?
Search40 , if you are not happy with the new image , please post what you dislike, if you don't, you are only making noise. If everyone was acting like you, the community would be useless.
Ha ha really, there is saying: If you know nothing, better say nothing, that all for you!!!!!!!!!!!!!
hello
I have installed the image but i have probleme withe dcc not conected
user root pass root
Hallo ans Team,
Ich habe heute meine Solo SE mit BH 2.1.5 beglückt und habe 2 Sachen zu bemängeln.
1. LCD4Linux (Keine Installation möglich) Egal welche Version. Fehler Python. Irgendwas fehlt da.
2. Im Menü fehlt "Aufnahmepfade" Ich kann meinen Pfad nicht Festlegen.
Könnt Ihr Euch das mal anschauen?
Danke
Gruß Pyromon
google translate:
Hello to the team,
Today I happy with my solo SE BH 2.1.5 and have to complain about 2 things.
1. LCD4Linux (Can not install) No matter which version. Python error. Something is missing here.
2. In the "record path" is missing I can not set my path.
Can you you look at this?
Thank You
Greeting Pyromon
Hallo ans Team,
Danke
Gruß Pyromon
google translate:
Hello to the team,
Thank You
Greeting Pyromon
1.
You can install (unpack ipk file with 7Zip and put files manually)
but then LCD4Linux panel will not look good
we have made certain changes to make LCD picture look good in LCD4Linux panel.
This is why does not allow installation.
Or wait a next image I think with a new version.
2.Of course you can
System Menu >> Recording paths >> Make choose >>
for example you like to change Default movie location >> OK >>Menu button >>Switch to filelist >>OK>>select location e.t.c
Hello Matrix10.
Ok thank you for help. With the L4L i will wait for next Update. Now is not for me the best way.
And for the other problem. In Solo SE this point is not available. On my Duo2 is there. You really mean SoloSE?
I´m sure there is not . I have searching for. I can´t find it sorry.
System Menu >> Recording paths >> Make choose >>on SoloSE is not available.
Greetings Pyromon
Hello Matrix10.
Greetings Pyromon
About Recording Paths, enable Expert mode into Menu - Setup - System - Customize
