Black Hole Vu+ Ultimo 1.7.2 (media-tree)
I am going to try this. Thank you so much. But, Because I am new, How can I link the pc to my Ultimo. Do I have to do any specific setting onto my Ultimo or the pc. Would appreciate more your kind support.
You have to configure your Ultimo network setup to connect it to your home network.
Please let me know how to configure my Ultimo settings to connect it to my pc. I have Wireless network connection on my Ultimo and the same Wireless on the pc. But how to connect both of them?
You can connect your PC to your Vu+ in several mode.
Via FTP, via web browser, samba ecc.
For exemple, To connect by webinterface, you have to digit you Vu+ IP addess into address bar.
The same thing you have to do to connect by a software FTP or by DreamBoxEdit.
I am still trying to connect my Pc to the VU+ as advised. But:
(1) Do I have to physically connect them using an ethernet cable or wirelessly?
(2) Would The creation of Favourite Sat ch lists be done through the Pc (DreamBoxEdit) or the Vu+ ? If it is through the Pc, how to transfer the lists to the VU+?
(3) Can I use the DreamBoxEdit directly on the VU+ to do the job without the computer?
Thank you for your prompt valuable support.
1) You can use what you prefer.
2) You can create your favourite lists on your PC with DreamBoxEdit and upload them on your Vu+ by the same software.
3) Since it's not a plugin, but a windows software, you can't use DremBoxEdit directly on Vu+.
You can also modify your favourite list directly on Vu+ by selecting the channel list (up or down arrows button), pressing the menu button and selecting the items to add, remove or move.
My previous Vix Image included some settings or plugs-in to enhance the screen picture quality, It seems that I have lost these with my BH Image as I tried but could not find the necessary tools to do it. I also lost the date display on the Ultimo front panel. I only see the time disply without the date when it is switched off. Please advise.
Menu>setup>>system.......(Video enhancement settings & Autoresolution)
I tried that, but still some missing enhancement tools which are not there!
(1) Are there any other plugs-in to help me as it seems that some settings are missing?
(2) How can I restore the Date Disply (together with the Time) on the front panel when the system is switched off or in standby.
Appreciate more your kind response.
look @ the folowing place
long blue>Software management>advance Option>Packet Management>>>>> make the earth glow blue (reload)
Well done. Great! At last, I found the Video Enhancement Settings. The picture quality is now marvellous. Thanks a lot. But, for the second piont regarding The time and Date, Is it any way to disply Both The current Date and Time when the system is shut off or in standby? Please advise as I found it very usefull indeed.
I really found the BH Image is very excellent in performance, wonderfull in design, stable on display and rich in colour. It is like a RR car, a joy to drive and control. Thanks to the Marvellous Team by whom it is created, developed and maintained. Kind Regards.
It's a skin features, you should modify the skin.xml file.
Can anyone helps me please to identify that skin.xml file and how to modify it. I 'm hoping for a response ASAP. Thanks.
The Black Hole 1.7.2 is the most "stable" and fast version of 3.1.1 releases.
Based on Offilcial Vuplus image 7.0
Kernel: 3.1.1
Vuplus drivers: 20120126
Vuplus DvbApp: 20120204
MeoBoot: 1.0
Skin: Army MooD HD updated
NEW NEW NEW: Next generation Usb Tuner Drivers (media-tree bh build)
Wifi drivers: rt3070 driver updated with some BH patches
Fixed: Prevent crashes in plugins using infobar (double ok crash)
Fixed: Vuplus WirelessLanSetup bug (Cannot generate Passphrase)
Changelog Vu+ drivers: clean & speed up dmx driver
Add gstreamer plugin fragmented
Kernel: add igmp.patch
Fix serviecmp3 bug: stop response timeout when stream is HLS.
Fix youtube player of webbrowser launcher plugin: add code to select stream quality.
NetworkSetup.py : fix checkNetworkCB function to prevent crash error
HDMICEC : fix default device name
Vuplus Event : input 7 SN_b for MSA
Webbrowser: fix build bug.
Changelog about USB DVB & Wifi Devices:
- changed all set of DVB USB drivers: now with BH image there are the latest drivers available
- USBTuner 0.3.9: a lot of bugfixes to improve stability and performances
- Wifi (RT3070): applied some extra patches to Vu+ driver to improove dongle functions
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Merci beaucoup.
Thank you for responding. I just came on line to check my emails. Because I am new and interested to know, I will try now to do this and will let you know shortly.
User/share/enigma2 ? Which menu? Can not find User menu. .... I am not a professional. I will appreciate more your efforts to guide me with more details. Thanks.
