I just have 1 usb key connected,
after formatting it asks to restart to give a udid, it restarts and then I go and mount it as /universe
it then restarts but when I check if it is mounted correctly I see that the status in not mapped
Tried a different one but no joy, same problem.
The only doubt I have is that regardles if I connect the usb key in the top or bottom slot it says dev/sda1
Could that be the problem?
If so, please reflash your box with fresh image, and format your usb stick again using the usb format wizard, and then mount as /universe.
If that doesn't sort it, you are either missing a step out somewhere (doesn't sound like you are), you have incompatable usb sticks (unlikely) or you have an issue with your box.
Anyhow please try as I suggested, as we had many issue's in testing, but this was not 1 of them, and trust me when I say we did alot of testing with this new feature.
1.Format USB stick on PC FAT32
2.Start Usb Format Wizard with NOT CONNECTED USB stick
3.RED >> RED>>CONNECT USB STICK and format
4.After restat go to Devices Manager
5. Mount USB stick Red>> chose /universe
RED button save.
After restart you must have mounted stick in Devices Manager /universe
I have reinstalled the image and done all the tests in several ways but had no joy.
I have finally solved the problem though.
The problem stands in the format utility in the BH image.It basically does not format the usb key.
To prove that I have formatted the usb using the image utility and then checked on a windows pc and found out that the key becomes unformatted.
In order to make it work you need to format the key using a PC in ext3 format and then connect the key to the image and using the device manager mount it to /universe
In this way it works.
Hope my experience may help you
I've already formatted twenty times different USB sticks with BH image format utility
and not only me but all our team memebers.
Well maybe you you have some special case
Hi
To my Ultimo started only the Default Boot Logo from BlackHole.No matter which universe I start.
Where are the boot logos by Avalon,Chaos and Ghost?
Or does not this look like in the description?
It is very strange you have this issue, but it definatly works for me, as like Mx10, in the last week and a bit, I must have formatted all my usb sticks in my box more times than anyone else.
Main thing is, you have managed to get a stick formatted and now have Parallel Universes working
