Black Hole Vu+ Ultimo 1.7.4 Parallel Universes
Love the image, thanks BlackHole but when I load on multiquickbutton to tweak the remote I lose the red button to switch universe and I cant seem to map it back, is there a way around it or will I have to wait for a new version of the multiquick to come out?
Cheers
i would like to be able to connect to the black hole server for add ons ,picons,ect but i always get the message "sorry, conection failed"
everything else is working great, any idea why i can't connect ?
I'm sure you did, but did you try to reboot both dec and router?
hello to all!thank vu team for their support!!great images!!!i have a question.i am trying to change universe,now i am to black hole universe.i puss the red button bad the message says that no space available to expand my universe.what i am doing wrong???i didnt install usb drive.i supposed that ultimo has big memory.If i want to activate parallel dimension need to use usb???thats the normal for all??also what button i puss for information for the memoty space??
You need to attach an usb stick to be able to jump and use other universes.
I hv also same problemwith ultimo with 1.7.4 blackhole image in asiasat 100.5 dish-hd package. only one frequency 112522 can be scanned. 12582 , 12642, 12702 cannot be saned. i checked in sat find all four frequencies has 65 to 69 percent sigbal with 0 BER shown. but when tried to scan only first frequency work with 20 channels and all these channels r almost sd channels. no hd channels found, i did dvbs2 8qpsk but still no luck but same setting with dm800 works very well. hotbird hd has no problems. another thing this asiasat 100.5 has high symbol rate 40700 not 27500. please try to solve this issue if any one can help in this regard.
We do not have the possibility to test this satellite.
Do you have this problem with the original Vuplus image ??
Have you tried to send this question directly to Vuplus ??
I installed this image but found the HD picture quality to be a lot worse than in previous images. I have uninstalled and gone back to the previous version.
There isn't any picture quality worsening into this image.
I think you have simply check your setups.
hello again,i am playing my vu and i found that:TOTAL RAM 275196 and TOTOAL FLASH 449,912- is it correct ?????now i am using 25 percent flash and 44 percent ram.does vu has 512 ram and 1giga flash ....????
As reported in the past in this Board, this is normal. Box has correct RAM and flash sizes from their BIOS.
hello,today i saw that my ultimo when is in standby mode the fan continue to working.is a bag in the new image??in the menu the fan is off in standby mode.
how to solve asiasat 5 -100.5 East hd channels frequencies it search only sd channels. 12522 v 40700 8psk 2/3 but no search it shows frequency lock but didnt search any channel.
