Black Hole Vu+ Ultimo 1.7.4 Parallel Universes
how i can reflash my box ? i trying with usb but imposible is other way to do ? please help . vu+ ultimo
Format usb stick on pc as fat32.
Unzip the image, and put the folder (vuplus) and it's contents into the root of the usb stick.
Power on your ultimo, and when the display says press "-" press the "-" figure on front panel.
It will then flash your box.
hi i had donne this and i got frozen always the screem , i cant get more over this is very strange what can be ? , how i can get back normal sofware ? i can do this ? or i have to sent to factory
If you can not flash any image, then first try a new usb stick, and if you still have problems, then you need to return your box to the dealer you bought it from, as it sounds like it has a problem, and is still under warranty.
Hello
I have a strange problem
HD frequencies at 100.5 degrees do not search
But there was a problem with duo box
Hello
Vu+ Ultimo
All skins online you can download from image server.
Skins EclipseHD BH 1.7.4 (Black Hole E2)
Skins EclipseHD S BH 1.7.4 (Black Hole E2)
Skins EclipseHD R BH 1.7.4 (Black Hole E2)
Skins EclipseHD E BH 1.7.4 (Black Hole E2)
Skins EclipseHD B BH 1.7.4 (Black Hole E2)
Skins EclipseHD SR BH 1.7.4 (Black Hole E2)
Skins EclipseHD SB BH 1.7.4 (Black Hole E2)
Skins EclipseHD SE BH 1.7.4 (Black Hole E2)
Hi Is it possable to make the Army mood skin available in blue for this image.
i always get connection failed when i try to connect to the black hole server any idea why am i missing a set up some where ?
i'm running 1.7.4.0 now and still the same
Try to post here your network settings, so we can check.
1st lets see a photo of your settings!
2nd or try the NetworkWizard to setup/start the connections!
i have a lan connection with interface and dhcp enabled
everything else is working fine just when i try to connect to the black hole server for add ons or picons.skins or anything i always get the message sorry conection failed
Do you want to try to manually config your network connection?
i would like to be able to connect to the black hole server for add ons ,picons,ect but i always get the message "sorry, conection failed"
everything else is working great, any idea why i can't connect ?
