Black Hole Vu+ Ultimo 2.0.2 - Meoboot Revenge
lorenzo64
Black Hole 2.0.2 - Meoboot Revenge
NEW NEW NEW meoboot v2.0:
Meoboot has been completely recoded in order to:
Keep cpu usage to 0%
To be compatible with all OE 2.0 Vu+ images.
You can use meoboot for multiboot, to test any other OE 2 image, for example:
VTI
OpenAAF
OpenPLI
OpenSIF
OpenSPA
OpenViX
and so on...
You can also use meoboot to expand your flash.
For example install the latest Black Hole image in flash,
then install meoboot on a usb stick (i.e 4gb)
Now install again the same Black Hole image in meoboot.
Boot the Black Hole image installed in multiboot and you will have
4gb of flash space.
Black Hole 2.0.2 Changes and updates:
  • remove sctzap dvbtraffic.
  • Add new recipe e2openbhplugins
  • python: add python-beautifulsoup and python-dnspython
  • enigma2 add dependencies for ondemand plugin
  • r8192cu Added some devices to driver:
  • [wlan] added more options to RT5572 driver
  • [autoshutdown] adapted default time patch.
  • Online Feeds Settings: Now listed in alphabetical order
  • Bhsettings adjusted: meoboot device in device panels
  • Change device mount system to UUID=
  • Components/Harddisk: fix bug in hdd inizialization
  • picload: updates and optimizations ...
  • skin.py: make skin compatible with Openpli relative coordinates
  • Update translations: Estonian, Polish, French and Greek
  • [streamplayer] enhanced player and updated stream list.
  • NetworkSetup: added manual-nameserver settings
The image MUST be installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.0.2-vuultimo_usb.zip
DanielFran
BH Lover
Hello BlackHole Team!
Thanks a lot for the new version.
Just one question: skin.py: make skin compatible with Openpli relative coordinates
What does it means? Any skin working in Openpli is now compatible and can be used in BlackHole image?
THanks
Ev0
Admin
THanks
No it is purely to make it easier to port plugins such as ondemand over to work on BH
bjorntj
oki... Just thought that this was the reason why online update was introduced, so we wouldn't have to start from scratch when new versions were released....
BTJ
Ev0
Admin
BTJ
Online updates were introduced, to allow minor bug fixes and minor tweaks to be added without the need to do a full reflash eachtime.
Maybe in the future it will be used for incremental updates, but for the moment you will need to do a full reflash for each new image release.
Pedro C
Am I to understand that I will be able to restore my present personal backup after flashing this new image ??
Thanks
