Black Hole Vu+ Ultimo 2.0.2 - Meoboot Revenge
For those who have problems with the network
after image update (BH 2.0.2 A).
Switch to DHCP first in network Configuration to reset network
reboot.
After that, you can config your network if you like to change.
DNS name server is automatically configured
(though you can not see in Network panel)
you can also config manually.
hi after update; i have a prblem DNS?
answer is exactly above your post pal
reboot.
thanks.. working
:eek::D
Switch to DHCP first in network Configuration to reset network configuration
and reboot.
