Black Hole Vu+ Ultimo 2.0.2 - Meoboot Revenge
someone can help me?? i can find the OnDemand plugin!!!!
you need to open a telnet window and log into your box.
Then type: "opkg update" without the quotes and press enter
Then type: "opkg install enigma2-plugin-extensions-ondemand" again without the quotes and press enter.
This will install the ondemand plugin.
Once done, restart enigma2.
Hi i have just to say something this lastest image, the dns primary and secondary was not automatic done, I must manuaaly put my dns by hand, and this morning I just put the shoutcast plugin , the box make a crash log and the dns all two dissapear again , done again the same steps again... any reasons why this happening??
Have you made box restart or just enigma restart after crash.
I have now tested,
and network and DNS work after image crash and Enigma restart.
Maybe it was a special situation , next time try to make image restart.
after the crash, the enigma restart enigma alone, after that all the dns dissapear... so I restart the box and still the problem was there , and Inotice that I couldn't conect the shoutscast and realise that dns dissapear...
sorry I add the crash log here, I don't know How to insert the file here.. if later you wnt to delete that , will be fine for me..
Sorry
I have delete log is to long
next time pls update file.
MX
I have to say also that the shoutcast plugin is on my box in double press green bottom.. so what i did was , box on, double press green bottom and the press ok, and the crash appear.. the box restart enigma 2 and the dns from my box dissapear... ( remember also that when I put the new version all was ok, only dns numbers wasn't on the box automatically. ) I have to say that's is the first time happening to me, after I upgrade the image.
Possibly in connection with the plugin and change.
But my test showed no change.
Thank you for the image. I have however installed it on the Duo and I noticed that going on plugin downloads section says failed to connect. The box shows active internet connection. I then tested 1channel and icefilms plugins and they both crashed. Restarting the box a couple of times did not change outcome. I then went to ultimo and installed respective image and the same again happened. Plugins not working and failing to connect to the Plugins downloads menu.
Maybe it is just me. I have rolled back to 2.0.1 on both boxes now and they are both working.
Thank you
Thank you
Verify your DNS setup.
Super
Thx Bh Team
BH2.0.1 Rev A -> BH2.0.2
1. Personal Backup (of BH2.0.1 Rev A)
2. Install of BH2.0.2 via USB-Stick
3. Restore Personal Backup (of BH2.0.1 Rev A)
4. Device Manager
4a. Remounting USB to media/usb (the USB mount was not handled by "Restore Personal Backup", but the HDD mount was handled ok)
5. Reboot
6. DNS-setup must be setup again (the DNS-setup was not handled by "Restore Personal Backup", but that could be due to the DNS-setup changes made in BH2.0.2)
Hurraaaayyyy, Mission Accomplished, Running BH2.0.2
Thx Bh Team
FYI (minor issues):
1. 1080p is still present in the Setup wizard
Keep up the good work
Best regards
one another questions on OnDemand plugin has been update with ABC server australia, how can be uodate this plugin...
here are the notice
22.0.3.2013
-[OnDemand] Add ABC iView Player
-New player for our Oz users, Currently only available to users in Oz I'm afraid.
-[OnDemand] Update Credits-I forgot to add credits to Andy Botting for his great work on the XBMC ABC iView Add-on.
-[OnDemand] Update to ABC iView-I left a debug piece of code for exception handling in the plugin by accident. This would have prevented any categories from returning.
