Black Hole Vu+ Ultimo v.2.0.1 OE 2
I found a small bug in the new firmware.
When i go to the EPG and set a timer the ultimo does give the message that he is recording, but when i want to watch the recording the file size is 0MB and he didn't record anything.
But when i add a timer manually, the program is recorded and i can watch it. The filesize is the >0MB.
I use the following plugin for epg:
Cool TV guide.
There is no crash log because the box doesn't crash. everything seems to work oke but no recording.
Hope you can fix this minor bug
The rest of the image is great and verry fast.
TNX blackhole theme for your gread image and support.
After flashing with 2.0.1 I get serious green screen crashing after choosing to reload setting from 1.7.9 I guess everything has to be reloaded manually and you cannot use backed up settings from 1.7.9 is that correct. Thanks in advance for any replys.
Personal backup from 1.7.9 images to 2.0.x is not allowed.
Reconfigure manually your box.
Got it up and running but cannot get my bouquet to load. Bouque is E2BU and seems to load when put in etc folder but when installing seems to look on your site for info instead of the E2BU site. It then does not show up in plugins. Now you going to tell me its not compatable with this image and if not where can I find one that works for sky or 28.2
Apologies I think its something to do with E2BU changing its web site address.
Hi,
I love BH, thx for very good job!
I'm using BH 1.7.8 with success - it works fine with my C+ card.
But after update to v.2.0.1 my card reader stopped working - FTA chennels work fine.
It seems to be locked on CommonInterface and cannot get card working (not in upper slot nor lower) - is it issue in this BH's version?
How can I init CR?
Hi,
How can I init CR?
Banned for a week. Break rule n.4.
As always!
Great work BH-team!
Fast as a shark!
Best Image ever!!!
Greetings to you all coders, @Matrix10, @Army and all involved!
Say thanks to youré familys for spending all quallitytime for us BlackholeUsers!
Cheers
Pirre
o
Guys, could, please, anyone advise wether it is ok to upload personal backup from 2.0.0 to 2.0.1 version? I understand that you cannot update from 2.0.0 to 2.0.1 via feed, but can I use my personal backup from this version? I see nothing about this in the main topic re 2.0.1. Thanks in advance for those who replied.
o
yes, you can use personal backup from 2.0.0
C+ card stands form Cyfra Plus (Canal plus Poland).
BH 1.7.8 shows:
CAID 0x100
provid 0x068
address /dev/sci1
It work fine on BH 1.7.8 but on 2.0.1 card seems to be inactive - after recovering 1.7.8 from full backup it works fine again.
I read that it is good to clear HDD before updgrade (I left only movie folder), but no change.
BH 1.7.8 shows:
CAID 0x100
provid 0x068
address /dev/sci1
CA 0x100 = SECA Mediaguard
You need a CA CI module who support this kind of CA System.
End of story.
