Black Hole Vu+ Ultimo v.2.0.1 OE 2
Maybe I'm wrong
I think latest FPGA update for uno and ultimo was 22 Jan 2013
If you already have not made ​​that update
As far as i know, the latest firmware FPGA is ver. 4.5 (uno and ultimo)
Released sometime before BH1.7.7 (31. aug 2012)
If there exists a newer FPGA please let me know
(Where to download the newer FPGA)
Best regards
Are you sure? Maybe you did an mistype. Wasn't it at 2012?
I think you're right,
I do not know any more exactly.
and now I do not have time to find the exact date,
because I am in the company
22 Jan 2013 vuplus update fpga updater plugin but not FPGA.
So I do not know exactly.
before august 2012 its my friends box and he have done nothing so I guess he need to do it but the 2.01 loaded ok
FYI:
When pressing multible "Fast forward via 3,6,9" when watching a recording, sometimes the box is muted ("Mute icon on screen and no sound")
Best regards
All images for Ultimo can setup the 3rd tuner as DVB-T or DVB-C (it's a plug&play tuner with selectable tuner)
unit sees the tuner but does not find any signal on t or c settting on both t or c using the corrrect line input. maybe a setting i have missed or incorrect
Have you upgraded FPGA?
Have you setted up correctly the tuner into GUI?
I've moved recently the T/C tuner from Ultimo to Uno and works very good with a portable antenna for DVB-T services.
you need to update terrestrial.xml and cable.xml with frequencies accordingly to your location
I think it's not necessary, because actual BH2.0.1 rev. A files have all options on "AUTO". @paulrx: What is your location?
uk I am new to this I have ultimo and a duo and only have carried out auto scan I don't have the latest image in as yet but will later today
For UK DVB-T channel search do: Menu > Set Up > Channel Search > Tuner Configuration > OK on your DVB-T tuner > Terrestrial Provider - select Europe (Africa, Middle East) DVB-T frequencies. Afterthen Restart and search channels ;).
FYI:
1. Epg setup when gsod occurred: (enigma2_crash_1362506202_EpgView.log)
Standard BH epg disabled
Cross Epg enabled (usb-stick) with rytec-denmark and rytec-sweden activated
Action prior to gsod:
Dripling around in standard multi epg
2. Epg setup when gsod occurred: (enigma2_crash_1363677751_EpgManualDownload.log)
Standard BH epg enabled (media/usb) with rytec-nordic activated
Cross Epg disabled
Deactivated rytec-denmark so only rytec-nordic is active
(Did not reboot)
Manual epg download
Best regards
Keep up the good work
