Black Hole Vu+ Uno 1.7.6
Hello,
How to make "CH+" and "CH-" buttons to work as changing the TV channel up and down not opening up the Channel Bouquet list ???????? :wallbash:
Hi,
Well it looks like i sorted out the problem it appears to be the Version of Multiquickbutton on the server that is to blame, I have now tried 1.7.6 again and just put one plugin on which is Coolmans servers V5.6.2 and the red button now displays Coolmans guide.
I would just like to ask is there anyway to change the keymap file just so that i can have the CH+ and CH- button to work as changing the TV channel up and down instead of it opening up the Channel Bouquet list.
I know that other images have this mapped as default like Vix image but Blackhole seems to follow on from what dreambox do and these 2 buttons open the channel Bouquet.
Thank you
How are you sure the problem is multiquickbotton?
I'm not sure. Did you manage to remap any colored botton with new multiquickbotton after install cooltvguide 6? If so we can adjust multiquickbotton, but i don't think you managed.
Let me know.
Let me know.
I dont have Coolgiude V6.0 on my Uno i only download what is available from the BH feeds and nothing else so i put Cool 5.6.2 on last night and it is working as it should i dont want to put Multiquickbutton on just in case it interferes with Coolmans guide.
i will alter the keymap.xml to alter the CH+ and CH- buttons to how i want
Hi since the latest blackhole 1.76 image , icant use the pause, forward, fast forward buttons (3,6,9) on my Nstreamplayer plugin (nvod) someone any idea?
Regards,
Alex
I use without problems both cooltvguide and multiquickbotton that are on the BH server.
Those plugs don't interfer each other.
Where can i find HDM CEC configuration files ?
I need to get working my samsung tv remote play, stop , rec, fwd, rew, pause keys over hdmi cec
You can edit a .py : no need to recompile.
If you modify a .py, you must delete the associated .pyo
You stop the vuplus with the switch at the rear, then switch on : the .pyo will be automatixally recreated by enigma2 on next boot.
Advice : think to save the original files on your PC, in the case of....
:( .. ther is only enable and disable .... it's look like that i neet to modify a /HDMICEC/plugin.py and recompile it to get working these ****
HDMICEC plug is in /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC.
You can try to edit file plugin.py
