Black Hole Vu+ Uno 1.7.6
Looks like another fine image from the BH team many thanks. I currently run BH 1.61 and would like to update to this version will I need to update the bootloader in my VU+Duo first as I have not done this yet?
TIA Hally
TIA Hally
You should update bootloader first and then flash the new images.
Hi all,
I just installed the version 1.7.6, i noticied a weired thing: the led of my vuuno doesn't display the name of the Channel where i am, but it displays "vu uno" or "black hole".
Is there any thing i CAN do to fix this? Any suggestion Will be so much appreciated.
Thanks in advance.
Have you uploaded a channel list to your Uno if so press down or up arrow key and then the blue button to see if you have favourites in your list
Yes i uploaded it and i see my favourite list, but still don't see the name of the channel on the led of my vuplus uno
Shall i wait a fix or i have to goback to the old BH image ??
Sounds like when you have uploaded the channel list it has become corrupt somehow, why not try downloading some channel settings from the BH feeds instead and see if that fixes the problem.
I don't believe so cause when i just install the new image, i made a scan and the name of the channel is not displayed in the LED
