Black Hole Vu+ Uno 1.7.6
Hi,
thanks again for this great job.
Just one question : what about the ability to lock parallel universes introduced in 1.7.5?
Chris.
Edit : Oops :oops:. This option is still there...
hello.
thank you for your great image.i just have one question.
is there a way to disable the downloading of addons?by erasing or changing an url for example or something else.
thank you in advance
hello.
Why?
Anyway,,,if U don't use,,,its disabled,,,:sleep:!
Hello,
BH 1.7.6 is working fine, but Fancontrol 2 is not working with it. There is a bug, it stop working BH, and need to be reinstalled fully.
Before I had a Vti image and it worked very well.
Regards
hi to all
i buy uno and upgraded by bh 1.7.6 but when i scan single satelite nothing find !!!
i tested with another images but no solve my problem
Is it possible my problem is hardware ؟؟
when i tasted with menu>stup>service searching>satfinder it have snr & agc
help me please
Did you launch FPGA upgrade from green panel? If no press green key and then FPGA upgrade and then scan again.
