Black Hole Vu+ Uno 2.0.2 Rev. A
I am comming from 1.7.9 BH and this image is un useful for me because i can not load my personal back up.
Thx.
I upgraded from 1.7.7. to 2.0.2 and after installing asked to restore my backup i did it and my personal backup restored without problem , I have motor too and all motor settings restored successfully !!! after that if encounter any problem with any sat. delete that sat. and add it again.
I think your backup made on 1.7.7 is very old and was made on OE1.6 now BH have O.E2.0 used backup from old image i think will be made alot of problem in new image.
I think best is install all from begined and made new backup this new backup will be good to used on next version image based on oe2.0.
if i make reciver on night morrow i fin reciver off maybe shutdown is reason
That I did not understand.
In general, you have two main options.
1.You're putting your receiver in Standby
But you want to go OFF after a certain time.
(Example >>Let's say over night you like to have receiver OFF/ShutDown)
2. Enable action after inactivity.
Example
You watch TV and fall asleep.
In this case, you can use this option to switch off the receiver.
why after pressing blue / yellow , i see the flash in the red at 89% after disabling hbbtv in fast boot , on a fresh usb update ? is this normal ?
Have just upgraded to 2.2.0 Rev A and would like to re install the On Demand plug in, but the above advice seems a bit vague, can you be a bit more precise on how you install the On Demand plug in using telnet.
Also why has it disappeared from the Add Ons . Love all the work on the BH image.
Can anybody please explain this:
You also will need to check for and remove any vuplus folders found on your hdd or usb devices before you install this image.
I am going to upgrade from 1.7.9 and I have some recordings and other stuff on my hdd. I'm not sure which folders I have to remove from my hdd. Which folders are vuplus folders and is my recordings safe if I upgrade? Thanks!
It means you have to remove (or simply rename) any folder named "vuplus".
