Black Hole Vu+ Uno 2.0.2 Rev. A
How can i having more Flash storage. is always 97-99% with 2-3 skins
Use universes !
On black Hole flash image just add nothing ; then jump into one universe, and there you can download as many plugins /skins as you want
Edit : Shiro was faster !
Another trick to have more flash available for vu uno users that don't need hbbtv is:
telnet to your box and digit these commands:
opkg remove --force-removal-of-dependent-packages opera-hbbtv
rm -rf /usr/local/*
Use a usb stick 4-8 giga install meoboot, install Black Hole image in meoboot and you will have 4-8 giga of flash !
Or use universes.
Hmm, i think I will try universes because of the follow command
The image MUST be installed in flash.
rm -rf /usr/local/*
with this command i have 85% from 96%. thanks
i did meoboot my hdd, is it possible to restore my hdd now? the command mountpoints don't working!
rm -rf /usr/local/*
THANKS SO MUCH ,, THIS WORKS GREAT!!! FINALLY SOME SPACE ,,,,
After update to 2.0.2 Rev A I have lost my VU uno from my Network ?
I used to have VU /mnt/hdd as network hdd to share recordings with my Win7 PCs.
Now the receiver is totally absent from my network ! ?
I have setup, hostname and password as before. Do I have to Do any other setup I don't remember ?
From Lorenzo64's post about 2.0.2 A:
THIS IMAGE CAN BE ONLINE UPDATED FROM VERSION 2.0.2
For those who have problems with the network after image update.
1) Switch to DHCP first in network Configuration to reset network
2) reboot.
After that, you can config your network if you like to change.
DNS name server is automatically configured.
Try this...
2) reboot.
Try this...
My issue solved, I have forgotten to manually setup VU ip .
I had DHCP enabled so the rooter appointed other then my VU default network IP.(Network firewall is blocking all (except allowed) IPs)
Thank you " 50_lire " your replay made me remember. :victory:
When Uno 2.02 Rev Z will be released ? Time zone traditionally not working. Plugin sinchronization fron NTP server nobody can make. No cool
Are any known issues with My Tubeplayer ?
When i select a stream it doesn't play at once.
Firstly I wait until the message appears I press "Exit" to the message, then
I have to press "PLAY" wait 10-20 seconds press "STOP" press "PLAY" to start playing.
(Same issue with previous 1.7.x image and "My Tubeplayer" after applying the FIX1-2)
I have vu+uno. I like BH image. It is perfect in all respects. I have a problem in all BH OE2 images. I installed HDD as per BH instuctions but when I want to record a programme, it can't and the following message appears.
Any body have solution of it. Kindly brief.
I HAVE INSTALLED MEOBOOT ON HDD AND ON BH 1.7.9 IT RECORDS PERFECTLY AND MESSAGE DOES NOT APPEAR.
gsarwar
gsarwar
You have bad Settings/SAT List
Thank you very much But I have still problem in recording. Kindly see the following screen shots and advise more.
Ghulam Sarwar
