Black Hole Vu+ Uno 2.0.2 Rev. A
find on the net settings from @Likra
upload/FTP settings with dreamboxedit in your box.
If you have enabled/download settings with
green button >>Yellow>>Online Feeds Settings update >> remove/disable this
update first.
update first.
Thank you very much for guidelines. My problem for not recording is solved. I have installed Device Manager from extensions and HDD unamounted and then mounted as default.
