Black Hole Vu+ Uno v.2.0.1 OE 2
Sounds very familiar to me. Is the drive properly mounted via Blue Panel? Without doing so you will see the drive via the browser and can e.g. play media on it but it won't record to it giving the message you reported. This is very confusing at least in the beginning. I also learned that it should be formatted EXT3 and not NTFS.
Thank you brother for quick reply. I several times initialized. The message appear " No HDD or HDD not to be initialized"" I tried to my best but fail. Now I am going to install the previous version BH 1..7.9 .
I have a problem with BH 2.0.1, when I run telnet "ps" does not work I get the following message:
root@vuuno:~# ps
PID TTY TIME CMD
28460 pts/0 00:00:00 sh
28475 pts/0 00:00:00 sh
28480 pts/0 00:00:00 ps
and I can see the emus that are running, any suggestions to solve
Thanks
root@vuuno:~# ps
PID TTY TIME CMD
Thanks
you need to type:
ps -A
And talk of emu is not allowed on this board.
Thanks for the new image, works fine.
Maybe not the most important question but..can picon packs available under Addons be used for this image? The present picon packages are marked with -> (Black Hole E2), are they compatible with OE2? (sorry newbie here)
yes, you can use them without probs
Thanks for new img and corrections. I just want to know if pcsc is properly working now since this did not work in the first release 2.0.0.
Kind regards
Iffe3232
