Black Shadow 3 /XE /SE /SE P
It is not possible to download the log, I cannot start the decoder.
I need to uninstall the skin from USB at boot, can you please make that file?
Thanks
Thanks
If the GUI crashes, you can access the box via FTP protocol.
About revert the install I think Matrix10 can help you better than me :)
No way...Vu crashes before connecting the LAN/WLAN, I think the only way is to uninstall the skin at boot by USB but I don't know how to do it.
Very strange.
If the GUI crashes, FTP and other networking protocols continue working because they start before GUI....
Im sorry
Unfortunately a mistake in coding
I apologize.
Bug will be fixed.
You can do just delete skin folder BlackShadow3 with FTP
in / usr/share/enigma2
Delete BlackShadow3
Ok, after several attempts I could delete the skin through FTP.
Thank you for your precious help!
Going to make a full backup!
No need to make a Full Image Backup!
BH Personal back up is more than enough...store@HDD!
Its a very good feature/plugin , that BH Image has!
hi, just wanted to say that the version from this great skin for the bh 1.7.6 also works on the bh 1.7.7 on vu+
regards
