Black Shadow 3 /XE /SE /SE P
Then I have to look if I have some plugin disabled because not find it on the download server.
Thanks.
there!
With your image I could download it without problems, I was very lost in another menu convinced it was correct, when it was not.
Thanks.
Good skin. Well readable lists for not so good eyes.
Would be my favorite, but
2 Dislikes: The condensed info window in the blue panel and no live picture during multi epg.
One Problem: In cutlisteditor the picture is moved to the left and mostly hidden behind the cutlist (BH 2.0.7.2, DUO2).
Thanks.
Thanks.
Hi!
there are other skins in the BH server, you can install according to your taste :p
@fantome
Yes, I tried some and use NexGenGradient in the moment. The problem in this skin for me are the many light blue letters or bars. They give not a good contrast to the black ground.
