Black Shadow 3 /XE /SE /SE P
Neat looking Skin!
Love 2see more...Prince MX10!
Rgdz
a911
change :
new OSD coding and graphic ,
new graphic for select bars and buttons
added some new panels
changes in other coding
this skin is very fast
Matrix10’s Registered & Protected Graphic
  1. Copyright:All Rights Reserved
  2. Registered:Wed Mar 16 15:49:22 UTC 2011
  3. Fingerprint:Show digital fingerprint
    d55774d0421a925483686fca8cad723bd78dbfd05724682e1b46acbd7307e475
  4. Title:Black Shadow 3
  5. Description:Black Shadow 3 skin
  6. MCN:CE921-6R332-D5K2S
where to download this skin?? sorry if i seem stupid for this :)
In this moment can not be installed in BP, but You can ask author -@Matrix10 about possibility to make it possible in future...
با سلام
اول از بابت اینکه فارسی مینویسم معدرت میخوام چون انگلیسی بلد نیستم
واز زحماتی که بابت ایمیج میکشید ممنونم وخسته نباشید میگم
ولی چرا اینقدر پشتیبانی شما در مورد اسکینهای این ایمیج ضعیفه
ای کاش این مشکل بزرگ رو حل میکرداین
If You using Black Hole image
you can download skin from our image server
Green>>yellow>>Addons Download Manager>>Black Hole Image skins
با سلام
Use the Persian section, please!
It's the best skin out there! Is the 2.0.0 version compatible with the 2.0.1 firmware or there will be a 2.0.x version so i need to wait?
I avoid installing before an answer to avoid any possible crash/green screen.
Thank you
Thank you
I forgot to change.
You can use , but i have change version to BH 2.0.x
