lorenzo64
BlackHole Vu+ Duo v. 1.3.7 - oe 1.6
COSA E' NUOVO?
- drivers updated to 20101008
- Added wifi support
- NEW: color terminal
- fixed: Midnight Commander console file manager
- fixed crash bug in System Info
DISCLAIMER
L'IMMAGINE BLACK HOLE E' BASATA SUL FIRMWARE UFFICIALE VU+ E NEL RISPETTO DELLE LEGGI CONTIENE SOLO AGGIUNTE DI SISTEMA E MODIFICHE GRAFICHE.
L'IMMAGINE BLACK HOLE NON CONTIENE ALCUN EMULATORE NE' ALCUN ALTRO SISTEMA PER LA VISIONE DI PAY TV SENZA REGOLARE ABBONAMENTO O PER IL COSIDDETTO CARD-SHARING.
L'IMMAGINE BLACK HOLE NON CONTIENE INOLTRE ALCUN SISTEMA PER IL DOWNLOAD DA SERVER ESTERNI DI PLUGIN O SOFTWARES CHE POSSONO ESSERE USATI PER FINI NON LEGALI.
LICENZA (TERM OF USE)
L'IMMAGINE BLACK HOLE E' RILASCIATA PER IL LIBERO USO DA PARTE DI TUTTI GLI UTENTI A PATTO CHE NON VENGA MODIFICATA IN ALCUN MODO E CHE SIA USATA SOLO A FINI LECITI.
MODIFICHE O AGGIUNTE ALLA IMMAGINE BLACK HOLE CHE COMPORTINO UN QUALUNQUE USO NON LECITO DELLA STESSA, COME CARD-SHARING ED EMULATORI, SONO IN CONTRASTO CON LA PRESENTE LICENZA D'USO E COMPORTANO L'IMMEDIATA REVOCA DELLA STESSA.
Qui: http://www.vuplus-community.net/board/threads/blackhole-vu-duo-1-3-7-oe-1-6.529/
