BlackHole Vu+ Duo 1.6.3 Beta DTS
Logan said
Your disk IS NOT FORMATTED IN LINUX FILESYSTEM BUT IN NTFS WINDOWS FS. I suggest to format linux. If you want to mount an NTFS disk you can
test this:
- Edit file /etc/fstab
- add line:
/dev/sda1 /media/hdd ntfs-3g defaults,nls=utf8 0 0
- reboot box
This is an external HDD, I have already march with VTI 2.7 no problem!
thank you
test this:
- add line:
- reboot box
thank you
As i can see from your previous post ("fdisk -l" output) your disk is correctly detected.
Now you can do the mount in two ways:
1. edit your /etc/fstab as Logan said if you have connected your 3Tb HDD to your box
2. create a script who mounts the disk when you needs (via Green -> Blue buttons - I don't have a box to verify this now, I'm at work now).
but this HDD 3T slill detected as 800Go!!!!
Ok. I've read wrong size. I'm sorry!
It's very strange that your 3TB disk is detected as 800gb.
I've inside my Uno a 1Tb disk and all works correctly.
If you connect the disk to Windows, how much Gbytes are been detected?
NEUROSURGERY said: ↑
but this HDD 3T slill detected as 800Go!!!!​
But when a was installed VTI 2.7 in my vu+ duo the external HDD 3T , was detected correctly 3000Go, and worked correctly!!!!!
in windows 7, the HDD was detected 3T correctly, and work fine!
Hi
Same problem with this new beta image, i cant get mytubeplayer to work every time i go on mytube i get green screen
Any help?
Check attached crash log
Have you tested MyTube with a clear image without any plugins that are installed later ??
