BlackHole Vu+ Duo 1.6.3 Beta DTS
Dear angelofsky1980
please, is what the problem may be this : Note: sector size is 4096 (not 512)
the kernel does not recognize the sector size 4096
Dear angelofsky1980
I analyzed my 3TB HDD by Master EASEUS partition compared to my HDD from my ordinteur, here are a differences:
on 3T: bytes per sector =4096 ,vs 512 in 320GB
fils Recorded size: 4096bytes, vs 1020bytes for 320GB.
but the probleme the vu+ duo detect just: 12180 cylinders
with EASEUS partition detect 45599 cylinders, 255 heads, 63sectors
on the HDD 3To, I hope it will give you an idea,
thanks
Great Image Thx Alot BH Team = The kings of Images :)
Still have problems with Wireless dlink Dwa-140 and xtreamer Wifi Realtek RTL8192GU still no ip adress, could someone advise what wifi to use instead that is really working
D-Link DWA-140 should be fully supported: I have one of this device and works correctly with BH.
On restore using BH Personal Backup. Settings from Pauli Neutrino Keymap i wrong or default. I had to make new settings for this after restore. It worked in previous version 1.6.2.
Yesssssssss it works but only with no encryption = useless i wont have my wireless open just to use wireless with my vu+
On my home I use only WPA encryption and my DWA-140 works correctly.... I have abandoned it in place of a SiteCom N-300 Mini-Wifi Adapter :) (Realtek based wifi device)
Hi, there is problem when working the usual mode radio (in previous images too), when leaving from radio in tv - green screen, reason show picon in info bar in usual mode radio, problem is absent in alternative mode radio. (all skins with picon in radio info bar)
sorry bad english
1.6.3 reinstalled on the duo:
a867 from bh panel ok
pc/ ok
audio dts with analog out OK!! :)
audio dts with hdmi OK!!
all fine, all great thx
(only the little skin minor problem: exit from the screen on my tv (?) )
@angelofsky1980
All my mkv movies are located on internal 500GB HDD... Problem with DTS exist on 2 amplifiers (Harman Kardon AVR 260 via HDMI and older Philips FR996 via spdif optical cable)
