BlackHole Vu+Duo 1.6.4 Full Hdmi-Cec
ok heres a few more issues that i have noticed, you can turn the vu and samsung tv off from the samsung tv remote....so how do you turn the vu+ box back on from standby with the samsung tv remote ?..it cant be done unless you use the original vu remote to turn the vu back on???? also..if tv is turned off and then back on you loose anynet connection..you then have to search for connections again...this has to be done each time the tv is switched off into stanby mode...still have to use both remotes...
Hi guys,
these the results on my Sony Bravia KDL40EX721
TV Remote STB -> Vu+ STB working
TV Wakeup -> Vu+ Wakup not working
VU+ Remote STB -> TV STB working
the TV Remote STB also put my HT Sony BDV-L600 on STB
VU+ Remote STB put my television on STB but not the Home Theatre system
1.samsung tv remote can turn off tv and vu+
2.samsung tv can turn on tv and vu+
3.vu+ remote can turn off vu+ and samsung tv
4.vu+ remote can turn on vu+ but not tv
my model i ps51d555
hi
when i instaled
enigma2-plugin-systemplugins-videoenhancement_experimental-git20100405-r0_mipsel.ipk
it is not shown in menu duo
why?
About time for a new image :-)
Especially since I am not able to install any new plug-ins. (It just said 'Add-on installed', but installs nothing).
Go Blackhole!
Hi guys,
Hello! I have the same problem.
What plugin have this problem?
I had the problem with the newly uploaded IMDB plug-in. It simply isn't getting installed.
I have similar problems with other plug-ins as well. 'Add-on successfully installed' message comes up very fast, without any script execution messages.
Hi, just tested on Samsung UE46D8000.
Switching the TV on with its own remote doesn't wake-up the Duo.
Switching the Duo on with its own remote doesn't wake-up the TV.
Powering the TV off with its own remote does power off the Duo.
Powering the Duo off with its own remote does power off the TV
All other buttons work properly.
Problem. Even if I set NO on the "TV remote Control Standby" (standby for VUDUO), Vuduo enter in standby anyway. So I have always to use 2 remotes. Any way to solve it? Otherwise I have to switch HDMI CEC off. Please let me know.
Perfect image (updatede now to version 1.6.5) but both images HDMI CEC with my Samsung Ue40C6000 does not work.
Strange it seeems a lot of other Samsung TV are working
That is really strange, i've got your tv and it works fine.
The only thing that doesn't work is the wake up the with Vu+ RC.
Did you config hdmicec properly in blue panel?
How is your box connected to your tv?
i have connected the box with a HDMI cable to the first HDMI/DVI connector on the TV
I have also tried to connect it on HDMI2 of the TV but its the same
Did you configure properly in blue panel, hdmi-cec, connection of your box with TV?
