BlackHole Vu+Duo 1.6.4 Full Hdmi-Cec
Wow i was thinking about an update. But it seems that this img has lots of problems maybe its wise to take this ofline guys. I read to much about crashes and problems in this img. To be honnest i would not flash it this is a waste of time i will wait for the next version or updates
Anyway i am still enyoing the black holes they are the best so keep up the good work .
Crashes? Where? Any image with wrong or instable plugins make a lots of crashes.
I think it's more useful if someone who have crashes, post the corresponding crashlog to help the Team to solve the bug if it's related to Image.
This is a very good image, I'm using it with crossepg plugin and nothing else and I cant remember a crash. Thanks and keep up the great work!
What is the password/username for acsessing the decoder and using dreamboxedit? I can`t transfer any channels without pw/un. :confused:
Default:
user: root
password: NO PASSWORD (empty space )
If You want to set this:
1. On Your PC: START/in search area write "cmd"/ telnet IP ADDRESS of box
2. user: root
3. passwd
4. write new password , repeat same.
That is it.
hmmm...im on bh 1.6.2, might give this a try once ive saved my image....trouble is do i have to rescan for a;ll channels again, edit and save the channels, delete all porn channels, enter *****...etc....dont really wanna go through that again as it took me ages to sort out the boquets and channels the way i want them....main reason i want to do this new image is using one remote only...
Make personal back up and just come back it when installed new image. BP is in menu.
Why You do that with channels manual ? Easiest way is to put finished settings list which You can download from our addons server or from net and put it via dreamboxedit.
sorry guys im new to this vu+duo box...ok flashed new image..asked me to restore my settings which i did...all my channels and settings came up..great i thought .doesnt seem to be working...ive entered my cline in the "etc" folder.......loaded CCcam2.1.4 .....turned on CCcam2.1.4...but channels are still scarmbled only FTA are available....also ecm time is showing as "nan"...any help..ta
Please read forum rules.
No questions about emulators .
ok been trying for ages...but still getting all FTA channels...put back my 1.6.2 and all is working fine....just 1 question do i need to change the attribiutes for any of the necessary files..."cough"..you know which i mean...
ok all sorted...remote working with my samsung 40" series 6 lcd tv...however "yellow" button timeshift does not work...also red button for recording does not work....
