BlackHole Vu+Duo 1.6.4 Full Hdmi-Cec
i tested with sony 32" klv-v550 a
it worked for change chanel and green panel but anoter position not worked
thx BH teams
But we cannot test all tv recent models, so please help us reporting your tests too with your television model.
Hi , we go to the attack.
TV Samsung ;
Model : LE40C530
Firmware : T-MSX5DEUC-2011.1
Box VU+ DUO ;
Image : BlackHole 1.6.4 Full
Remote TV and Box VU+DUO all 100% .
Total commander TV and BOX running . Works fine ...
Thanks you . Great image . ;)
Sony KDL 40-WE5
- Circular button (with OK button in the center) - up/down works left/right works
- OK button works
- Red, Green, Yellow, Blue buttons work --> But long press does not
- Power options - 1 and 3 work, 2 doesn't
- Return button maps to Exit (works)
- 'Sync Menu' button maps to Menu (works)
On the whole, excellent work BH Team :)
Sony Bravia LCD KLV-40EX400
Same functions work as mentioned above by "trobaldy" .
Opt 2 - Power Wakeup does not work:confused: !
Keep it up BH team - Excellent job.:thumbup:
B/Rgds
Supermario
After further testing:
Sony KDL 40-WE5 contd.
- Number buttons (0-9) do not work
- Bouquet change via Program +/- button does not work (this is perhaps a deal breaker)
- Volume control does not get mapped to Volume +/-
- No corresponding button for EPG
Also slight lag experienced as compared to direct usage of VuPlus remote.
To summarize: If we could get the bouquet changer mapped, I could throw away the VuPlus remote. :)
Philips 46 pfl 7655 (same with 7605, 7665, 7685)
port: HDMI 1
image: BH 1.6.4 hdmi-cec
box: VU Duo
vu+ > tv hdmi 1
option 1: OK
option 2: NOT OK
option 3: OK
I have a Philips 32PFL9604H
When I go into the HDMI-CEC and save the options with the red button, the remote control of my TV starts working with the Vu Plus Duo but not all the commands work.
The media player does not work.
If I switch to the watching TV the remote control of my TV loses the connection to the VuPlus, it is not activated when I switch back to the VuPLus.
Same problem on my Samsung LCD
