BlackHole Vu+Duo 1.6.4 Full Hdmi-Cec
Very strange!
The error I detect on your log mean a missing file:
/tmp/ecm.info
Please post the output of this command:
df -h
I think you have a full flash ....
thx for quick reply angelofsky1980
oh i see it inside my *****.cfg i have enabled DEBUG : yes . And the warnings.txt was full and Big.
perhaps that is reason? I make Debug: no and will try again.
root@vuduo:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 118.0M 46.5M 71.5M 39% /
tmpfs 64.0K 12.0K 52.0K 19% /dev
/dev/sda1 232.8G 12.0G 220.8G 5% /media/hdd
tmpfs 69.1M 612.0K 68.5M 1% /var/volatile
/dev/sdb1 3.7G 293.5M 3.4G 8% /media/usb
root@vuduo:~# root@vuduo:~# df -h
-sh: root@vuduo:~#: not foundFilesystem Size Used Available Use% Mounted on
root@vuduo:~# Filesystem Size Used Available Use% Mounted on
-sh: Filesystem: not found
root@vuduo:~# /dev/root 118.0M 46.5M 71.5M 39% /
/dev/sdb1 3.7G 293.5M 3.4G 8% /media/usb-sh: /dev/root : Permission denied
root@vuduo:~# tmpfs 64.0K 12.0K 52.0K 19% /dev
-sh: tmpfs: not found
root@vuduo:~# /dev/sda1 232.8G 12.0G 220.8G 5% /media/hdd
-sh: /dev/sda1: Permission denied
root@vuduo:~# tmpfs 69.1M 612.0K 68.5M 1% /var/volat
ile
root@vuduo:~# /dev/sdb1 3.7G 293.5M 3.4G 8% /media/usb
thx again
bye
Hi all. A small bug(?) in all BH 1.6.x images. There is empty space in bottom of the screen when EPG list is showed. Why?
thx
root@vuduo:~# df -h
ile
thx again
bye
Your problem was related to your emu (not supported in this Board - read Rules for more infos). Please cofnigure it correctly.
Sony Bravia KDL46EX713
TV Remote puts TV and Duo into Standby
Duo Remote puts TV and Duo into Standby
Left, Right, Up, Down, OK on TV Remote function as on Duo Remote
Red, Blue, Green, Yellow on TV Remote function as on Duo Remote (apart from long-press)
Key below the '9' (subtitles) on TV remote functions as 'Menu' on Duo Remote.
'Guide' key on TV remote functions as 'EPG' (once in EPG, numeric keys 1-4 (EPG search, etc) don't work. (Long-press EPG doesn't work).
'Return' and 'Exit' on TV remote both function as 'Exit'
Switching the TV on with its own remote doesn't wake-up the Duo.
Switching the Duo on with its own remote doesn't wake-up the TV, nor does it switch the TV to correct HDMI port (if the TV is already on).
Panasonic TX-P50V20E:
Switching the Duo on with its own remote doesn't wake-up the TV.
Powering the TV off with its own remote does power off the Duo.
Powering the Duo off with its own remote does power off the TV.
Do i need to do a total new install in the flash, so all my add-ons and setting are gone, or is there a trick to do this, I’m am using the previous Black hole..
You can use BH personal backup.
Press menu, bh personal backup, setup to choose where to save settings, then backup.
Now you can flash new imgs, then go to menu, bh personal backup, restore.
You will have all your old settings, except crossepg settings and multiquickbotton settings.
Philips 42PFL7695
If Balck Hole server has been disconnected?
From yesterday until now, I do everything, I can not get connected by my Vu+ Duo to Black Hole server.
:thanks:Thanks:thanks:
Has anyone else noticed the issue where the Menu screen automatically comes up (without the Menu button being pressed)?
