BlackHole Vu+Duo 1.6.4 Full Hdmi-Cec
Not really. I wonder why that happens though.
The Main Menu only shows with pressing its button and never automatic , is the image a backup and installed @ USB flash using Meoboot , or may be the BH corn manager is on?
crashing about once a day.
from log
  File "/usr/lib/enigma2/python/Blackhole/BhEI.py", line 215, in __updateEmuInfo
IOError: [Errno 2] No such file or directory: '/tmp/ecm.info'
(PyObject_CallObject(<bound method Nab_ExtraInfobar.__updateEmuInfo of <class 'Blackhole.BhEI.Nab_ExtraInfobar'>>,()) failed)
        </enigma2crashlog>
'/tmp/ecm.info' file is there
root@bm750:/tmp# ls -ltr
srwxr-xr-x    1 root     root            0 Jan  1  2000 Blackhole.socket
--wx---r--    1 root     root           12 Jul 30 19:26 myip
-rw-r--r--    1 root     root        13050 Jul 30 22:47 smb.log
srw-rw-rw-    1 root     root            0 Aug  1 18:51 Bhapi.socket
srw-rw-rw-    1 root     root            0 Aug  1 18:51 camd.socket
-rw-rw-rw-    2 root     root          208 Aug  1 19:02 ecm0.info
-rw-rw-rw-    2 root     root          208 Aug  1 19:02 ecm.info
edit:
There was also another log from yesterday
main thread is non-idle! display spinner!
[EPGC] 192898 events read from /media/usb/epg.dat
ERROR reading section - Value too large for defined data type
poll: unhandled POLLERR/HUP/NVAL for fd 29(8)
poll: unhandled POLLERR/HUP/NVAL for fd 34(8)
[EPGC] store epg to realpath '/media/usb/epg.dat'
[EPGC] start cleanloop
[EPGC] 81078 events written to /media/usb/epg.dat
PC: 00480f94
 00000000 10008b01 00000001 2c85786d
 03000003 00000001 00000001 00000001
 00000001 00000000 00000001 00000001
 00000001 000000db 2c85786d 2b516ca8
 005ce5b4 02f05880 00745ed4 00000000
 00013cb6 7ffa04ec 7ffa04f0 7ffa04f8
 00000000 2b4336a8 00000001 00000000
 2b51f960 7ffa0498 2ca488ac 00480f8c
As a final action, i will try to dump a bit of code.
I just hope that this won't crash.
00480f94: 01 00 87 90 02 00 e5 24 e0 19 11 0c 21 38 20 02 cc 1a 11 0c 21 20 00 02 18 00 a6 8f 21 80 40 00 (end)
[EPGC] stop cleanloop
[EPGC] 6337552 bytes for cache used
        </enigma2crashlog>
from log
        </enigma2crashlog>
edit:
PC: 00480f94
        </enigma2crashlog>
I think you have full flash or other thing of problems related to emu.
Some System info
Ram: 66%
Swap: not in use
Flash: 45%
USB: 55%
Extras to plain 1.6.4 is Suomipoeka+MultiQuickButton+Emu, settings & plugins/emu restored with Personal Backup from 1.6.3.
GSOD´s comes when just watching live TV and doing nothing with remote.
When I press the "TV" bottom, and get the screen with channels, i don't get the preview window anymore; there is just a part of the picture from the background in the small preview window not like before I have a small preview of the whole screen, do I something wrong??
Bouquet Backup is not working for me - there is no chanels on the backup bouquet when i restore it - any idea?
Hi
Have you tried your motor setting. Press Green Button then Press Yellow Button then goto Addons Download Manager (press)then goto Settings(press) then Press on one of these settings. Hopefully this will work for you as it did for me. :idea:
I must to rectifier my previous post. When I press the standby button on my Lg 60PK250 remote control then Vu+duo came in "main menu" and not in standby mode and I must press exit on Vu+ remote control to standby Vu+. In 1.6.3 image it was correct.
Here my HDMI-CEC report:
Onkyo TX-SR576 Surround-Amp, Toshiba 46FZ355D LCD-TV.
VU+ -> Ampli HDMI1 -> TV HDMI 1.
Where is Point 4 "Vu+ remote control wake up -> wake up TV" ;-)?
When I choose standby on Vu+, TV get on standby, and then Amp get on standby (this is a HDMI-CEC function in the Amp).
But it does not wake up TV, when the Vu+ wake up.
And I can use "Regza-Link" on the Toshiba remote.
But this is bad and not usefull.
It makes only sense to use only the Vu+ remote. ALL buttons with correct labels.
And a better haptic.
"Point 5":
Please make this possible: "Vu+ remote control Volume up/down -> Volume up/down Amp".
A very important function. You know, you can't level AC3 with your Vu+ remote.
This old problem would be solved very comfortable!
